Kind of an odd request,
Looking at swaping a 4BT Cummins engine into a 2000 GMC Sonoma 2.2 Flex fuel
Obviously this engine does not require a and ECU to run. I am interested in keeping the ECU for trans control, gauges etc. I will be able to provide the correct input to the ECU for engine speed, and TPS (anything else?). Is this something I could conceivably do with EFILive? I know you can disable codes for emissions, O2 sensors etc but can you strip it down to a point where it is not throwing codes for no injectors, coils, knock sensors etc?
I have access to EFILive though a co worker, just wondering if I should buy a license for this ECU.
Thanks!
