Results 1 to 10 of 20
Thread: CSP5 "Switch FALIED"
    Dec 2013
    Default CSP5 "Switch FALIED"
    Anytime I try to switch tunes I get a "Switch FAILED" message from the Autocal. The CSP5 file downloads without any issues to my 07 truck, I'm on the latest firm (Nov 5), I followed the instruction to a tee, and have updated all the EFI 7.5 and 8 programs. Any ideas as to why I keep getting this issue?
    Dec 2005
    Is your switch one of the Socal Diesel CSP5 switches ?
    Or is it from another company ?
    www.mscservices.net
    Oct 2012
    You still having this issue?
    Nov 2005
    Quote Originally Posted by GMC-2002-Dmax View Post
    Further to Tonys question, what software and firmware versions was your tuner using to create the tunes, and what has your tuner said?
    Cheers
    Cindy
    Oct 2012
    I've had this issue on a few trucks now, it worked with the first pre-release but now that I've updated to 2.07.52 (firmware) 2.07.06 (boot block) Software is build 237 (v8)and v7 build 245. I'm using so-cal switches. It'd be nice if there was a way to troubleshoot this a little. I'll have to get a couple trace files to send.
    Nov 2005
    Quote Originally Posted by blklmm View Post
    The changes between the first pre release and the current release were designed to improve response rates and reduce chatter. What else is on the vehicles you are having trouble with? Are you using the scan tool concurrently and what aftermarket devices are installed?
    Cheers
    Cindy
    Senior Member WyoFreeride's Avatar
    Sep 2011
    Did you rebuild the CSP tune from scratch with the newest version or are you still using the file created with the pre-release software?
    2010 Dodge QCSB 6.7 Auto
    Feb 2014
    Any luck with this? I'm having same problem. My CSP5 won't work either. Been working on it with tuner for a while now with no luck.
    Nov 2005
    What software, firmware and bootblock are you using? Are you switching via FlashScan v2, AutoCal or a 3rd party switch? If a 3rd party switch, have you tried using your EFILive hardware for switching?
    Feb 2014
    I am using my AutoCal and CSP5 with pass through. I use V8 \firmware 2.07.53 date 11/19/2013\bootblock 2.07.06 date 8/2/2013. I have a feeling it may have to deal with me upgrading to the pre-release software. I'm told I can't go backwards on firmware either.
    07 5.9 Cummins
  1. "File Sys FULL!" followed by "ERROR: $0520"
    By Sushisan in forum AutoCal
    Last Post: April 24th, 2012, 06:35 AM
  2. '05 "T" and "Z" motor differences
    By Boost in forum Gen III V8 Specific
    Last Post: May 16th, 2011, 03:54 AM
  3. Replies: 3
    Last Post: March 6th, 2011, 02:12 PM
  4. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  5. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
