Results 1 to 2 of 2
Thread: truck surges when AC on and in Drive at idle speeds only.
    Jun 2010
    Default truck surges when AC on and in Drive at idle speeds only.
    did a tune for a buddy. truck runs great idles great but when he turns on the ac and puts it on drive it surges and causes it to pull timing and not want to idle. but only at idle speeds if he taps the gas and gets it to 1000rpm its perfectly fine but as soon as he lets off the compressor doesnt go on and it stops blowing cold air and starts to surge. only thing i can c on the log is rpm dropping and timing dips in a consistent pattern. any idea why this is happening? log if file attached...
    There are idle tables for AC on and AC off... might want to compare these.
  1. High Idle Switch for Drive by Wire 5.3
    By BioHazard73 in forum Gen III V8 Specific
    Last Post: April 23rd, 2013, 03:04 PM
  2. Idle A/F ratio rich, OK when put in drive, LS1 Trans AM
    By RamAir in forum Gen III V8 Specific
    Last Post: November 10th, 2012, 01:57 AM
  3. Cant get truck to idle
    By SUPERTRUCKER in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2010, 12:52 AM
  4. A/C surges when slowing down
    By whackem04 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 1st, 2009, 03:02 PM
  5. Can't get my truck to use the idle park/neutral tables
    By Highlander in forum General (Petrol, Gas, Ethanol)
    Last Post: October 17th, 2005, 03:05 PM
