Results 1 to 5 of 5
Thread: LBZ MAF Bounce
    Junior Member xploitdiesel's Avatar
    Jun 2012
    Default LBZ MAF Bounce
    Had a customer complain of a slight surge at certain times. Sure enough we drove the truck and I logged it and there was a slight surge where desired rail pressure dropped etc... so looking into what could cause this I noticed(wasn't hard to miss) the MAF was bouncing throughout the drive...at idle it was fine and stable, but under load it would bounce to 40 and back to 5 lb/min and the back up...it did this constantly under ANY throttle. The customer has an S&B air intake and I did a quick check for leaks. Is it possible the MAF sensor needs to be cleaned or replaced or is there some quirk I'm missing. This was a DSP5 tune as well running 52606128 OS. The truck ran fine for 6 months, so I was certain it wasn't my tuning that just now caused this...as I have tuned many and this one is a first...
    Regards,
    Kyle Ensley
    X-PLOIT DIESEL PERFORMANCE
    www.xploitdiesel.com
    kyle@xploitdiesel.com
    The air intake plumbing/tube/lid/airbox is causing this, install the stock plumbing/tube/lid/airbox and see the MAF bounce minimizes
    ( I see this on gasoline vehicles quite often )
    Apr 2008
    Is it pushing open the egr seen it happen at high drive pressure.
    stock sucks
    Jan 2006
    As stated above, when the EGR opens, the MAF will reduce logically. I don't think 40 to 5 is expected, so I would investigate EGR correlation, before replacing the MAF
    Custom Tuning Services
    Jun 2012
    I should have mentioned that the egr is blocked and disabled.
    Regards,
    Kyle Ensley
  1. 4L80E WOT shifting problem. 1st-2nd bounce rev limiter!
    By TransAm-Z in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 20th, 2013, 10:41 AM
  2. e38 6.2L conversion from 5.3L timing bounce in park only not drive XXX
    By huttner1 in forum E37, E38 & E67 PFI ECM's
    Last Post: June 13th, 2013, 09:31 AM
  3. Getting DTC 0172&0175, WBO2 bounce
    By Ram Air IV in forum General (Petrol, Gas, Ethanol)
    Last Post: September 13th, 2009, 07:13 PM
  4. Replies: 10
    Last Post: August 27th, 2009, 10:38 AM
  5. Valve Bounce identification logging
    By oztracktuning in forum General (Petrol, Gas, Ethanol)
    Last Post: June 1st, 2007, 01:01 AM
