Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: A question for you head and cam guys.
    Lifetime Member johnsZ06's Avatar
    Sep 2003
    Default A question for you head and cam guys.
    Is anyone who is running a decent size cam and "supposedly" has a good tune, noticing your exhaust tips still sooty?
    My tips will turn black after a few WOT runs even though I have 13:1 commanded and showing. The rear fascia of my car is constantly spoted with soot!
    Maybe I need to hire a chimney sweep to correct this problem!
    Jan 2005
    chimney sweep will help.
    I had a soot problem for a while. would even leave exhuast tracks on my driveway during warm up. My problem wasn't in the tune. It was oil getting thru the pcv. During my last tear down, I upgraded to the ls6 valley cover and still run a catch can. I only get soot now when it's time to empty the catch can.
    Sep 2003
    Quote Originally Posted by TAQuickness
    Really? That's interesting. I already have an LS6 valley cover. When I removed my intake not to long ago to install new lifters, I noticed quite a bit of oil in the intake. I wouldn't have thought that would cause such a sooty exhaust. I guess I'll have to give the catch can a try!
    Jan 2005
    Oil does wonders in the combustion process
    Does your oil smell like fuel? If so, you are running rich, part of the soot problem. Fuel in the oil will change the viscosity making it easier to get thru the PCV system.
    You might also try an idea posted by Joecar (I think this post is in the lounge section). His thought, and a damn good one, is to re-rout the PCV to pick up from the oil filler neck. IIRC, the Dodge Caliber has a similar style PCV system.
    Sep 2003
    I've never noticed fuel in the oil.
    Do you think of just venting both vave covers and eliminating the PCV sytem would be worthwhile?
    Lifetime Member Bruce Melton's Avatar
    Oct 2003
    I had that problem when I had a bad MAF-- new MAF fixed it. I am olde school.
    The oil in intake is a tough one and I have tried everything (ls6 valley, no PCV valve, breather vent, catch can etc) and still get it. For me the soot and "black ass" as I called it, was not related to oil in the intake as much as super rich startup.
    PowrMax Performance
    100 mm PowrMAF
    Sep 2003
    Quote Originally Posted by Bruce Melton
    Bruce,
    Have you since eliminated the problem?
    Guys in the Corvette club nick named my car "dirty butt".
    Oct 2003
    Quote Originally Posted by johnsZ06
    Bruce,
    "black ass" -yes. Still gets C5 dirty quick but not sooty. Still get oil suck, esp during track days. I think when you are off the trottle at high RPMs the vac in the intake is too much.
    PowrMax Performance
    100 mm PowrMAF
    Oct 2003
    Mine has the dirty butt thing going on, speedway white...............guess I need to hook up that LPE catch can I bought - last fall!!
    joel
    Sep 2003
    Could it be not enough timing in the PT areas causing an incomplete burn in the exhaust system
    EFILive - The Single version of the Truth
    Larry - HumpinSS
  1. Simple question for you Guys................
    By FreddyG in forum Gen III V8 Specific
    Last Post: April 21st, 2009, 12:53 PM
  2. Question guys
    By txchevy in forum Gen III V8 Specific
    Last Post: April 12th, 2007, 04:23 PM
  3. Hello all, got a question for you guys
    By gcross in forum Gen III V8 Specific
    Last Post: December 15th, 2006, 12:08 PM
  4. quick question for you guys...other vehicle types
    By soundengineer in forum General (Petrol, Gas, Ethanol)
    Last Post: February 13th, 2006, 12:21 PM
  5. A Simple Question For You Australian Guys...
    By DramaFoYoMama in forum Lounge
    Last Post: January 19th, 2006, 10:40 AM
