Results 1 to 3 of 3
Thread: 24x SBC and LT1 Conversions with both CKP and CMP in Timing Cover
    Aug 2006
    Default 24x SBC and LT1 Conversions with both CKP and CMP in Timing Cover
    For much of this year EFI Connection has been working on a new crank/cam signal conversion for both SBC and LT1 engines. We set out to accomplish two things...
    • Eliminate crank signal issues where aftermarket double row timing sets are used. This has never been an issue with all double row timing sets, but occasionally we have received feedback where a double row timing set is the culprit in moving the crank reluctor out of the sensor range. A new reluctor design (and compatible sensor) have resolved this problem.
    • Move the cam signal to the face of the cam timing sprocket - just like a Gen IV LS-Series engine. For SBC installations, this eliminates the adjustment of the Vortec distributor to get the cam signal in proper relationship with the crank signal. For LT1 engines, this eliminates the use of our cam sensor housing in the front of the timing cover and provides an opportunity to make a higher resolution cam reluctor (cam signal on a larger diameter face).
    Both solutions are accomplished with the new 24x SBC and LT1 conversions.
    24x SBC Kit with Camshaft Sensor in Timing Cover
    This conversion kit consists of a new billet aluminum timing cover (manufactured in-house), 24x crank reluctor (manufactured in-house), CKP sensor, Cloyes 9-3545X9 billet double roller timing set with custom cam sprocket (machined in-house for 1x CMP signal), and Gen IV LS-Series CMP sensor. The only caveats are the requirement of a crank balancer no thicker than production GM 1996-up (which is about 1.325") and the requirement of a step nose camshaft (like 1987-up hydraulic roller engines). We will probably work with Cloyes again this year to develop a new timing set for flat nose camshaft applications, but there is nothing we can do about the balancer thickness requirement. There's no room to move the crank reluctor and sensor closer to the engine because of the timing set. More options at http://www.eficonnection.com/eficonnection/24xSBC.aspx.
    24x LT1 Kit with Camshaft Sensor in Timing Cover
    This conversion consists of a new billet aluminum timing cover (manufactured in-house), 24x crank reluctor (manufactured in-house), CKP sensor, Cloyes 9-3545X9 billet double roller timing set with custom cam sprocket (machined in-house for 1x CMP signal), Gen IV LS-Series CMP sensor, and a late LT1 crank key. More options at http://www.eficonnection.com/eficonnection/24xLT1.aspx.
    24x LS1 PCM on Early Small-Block Chevy and LT1/LT4
    Aug 2006
    Here's a picture of our new SBC timing cover installed. Machined 6061 aluminum. Anodized black. Face milled for additional logo detail.
    Looks nice and sharp.
  1. New 24x and 58x for SBC and 4.3L V6
    Last Post: April 29th, 2013, 02:17 AM
  2. 58x for SBC, BBC, and LT1/LT4
    Last Post: January 14th, 2010, 05:34 PM
  3. Billet SBC Timing Cover
    Last Post: December 16th, 2009, 12:53 AM
  4. Billet LT1 Timing Cover - Clears Double Row Timing Chain
    Last Post: November 17th, 2009, 01:15 AM
  5. EFI Connection 24x Electronic TPI/LT1 Drive-by-Wire Throttle Bodies
    Last Post: May 26th, 2009, 01:52 PM
