Results 1 to 7 of 7
Thread: LS1 VE Table, Calculating from 15 kPa all the time?? Need Help
    Feb 2013
    Default LS1 VE Table, Calculating from 15 kPa all the time?? Need Help
    I'm still in the "learning stage" with EFILive. I've run a few scans, and I'm concerned that when I pull up my tuning software while scrolling through my scans, no matter what my measured MAP actually is, the software is indicating that my PCM is calculating anticipated airflow from the 15kPa column only, in the VE table (and backup VE table). In all of the other charts, the "grey highlighted box" correlates with the scan as would be expected, so I'm pretty sure there's nothing wrong with the software. Is my car really calculating from 15kPa when manifold pressure is 55kPa, for example? I believe the condition would be very noticeable, but again, I'm new to this. Before I bought the car, previous owner told me it's been "tuned." I don't know what's been altered.
    Another thing worth mentioning is that when I run a scan and record the "commanded AFR," it's always 14.63 across the board, and just from looking at my fuel command at open loop I know it should not be "commanding" 14.63 100% of the time. Are these two things related in any way? My wideband meter isn't here yet, so I'm not messing with fuel/air just yet, only observing what I can.
    1998 LS1 Trans Am
ID:	16237Click image for larger version.
    Apr 2009
    you need to make sure the PIds are all correct in the map. Its not hitting all the cells because you dont have RPM or map set correctly.
    Josh
    1996 WS6|M6|CC305H|MMS Stage II Heads|Crane Gold 1.6 RR's|42 Lb Injectors|ATI P600B@12Lb's|3 Core ATI|BBK 58mm TB|SLP Shorties|Borla Catback||MWC&P FAB 9 w/3.70's|SFC's|LS1 Brakes|MSD 6AL|
    WIFEY: 2005 SBM TAHOE 4.8L. MAGNAFLO, HID'S,
    Jan 2006
    I posted on ls1tech how too fix. Most likely need to right click SAE.MAP and click metric and it should fix it.
    +1 what minytrker said...
    in scantool, on PIDs tab, on MAP pid, do rightclick->Metric; then restart tunetool.
    Avoid logging and using the pid GM.AFR... use the pid GM.EQIVRATIO instead.
    And for a BEN pid, use the pid CALC.WO2BEN from the Calc.VET thread
    CALC.WO2BEN is defined as {GM.EQIVRATIO}*{EXT.WO2LAM1}
    if you don't have serial comms from your wideband, then replace {EXT.WO2LAM1} with a suitable lambda pid, e.g. {CALC.AFR_LC11}/14.7.
    Feb 2013
    Changed PID to metric and it works now. That's a relief! I'm still waiting on my wideband to get here. Is it difficult to get the NGK AFX to work? I see more than one PID selection for it. Haven't read up on this part yet. Thanks for all the help!
    In regards to wideband, have a read thru post #1 of the Calc.VET thread: Calc-VET-correcting-MAF-and-calculating-VE-(in-single-log)
  1. Replies: 5
    Last Post: August 31st, 2011, 10:32 AM
  2. 105 kpa in boost ve table (cos3)
    By LS1Nova in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 18th, 2010, 09:11 AM
  3. Replies: 11
    Last Post: July 10th, 2008, 11:44 AM
  4. Knock table only produces all 0s all the time
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: October 18th, 2007, 03:10 AM
  5. boost tuning - 105 kPa table
    By SS2win in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2005, 02:03 AM
