Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 81
Thread: Manual vs Auto
  1. #51
    Quote Originally Posted by ezobens View Post
    1. B0701: Disable Catalytic Converter Protection
    Insures accurate stoich and PE mode/WOT Fueling
    If you have catalysts, set this to enabled, otherwise leave this disabled.
    2. B0120: Change RPM Threshold for Airflow Calculation from 4000 to 400
    Eliminates any Airflow Correction from the VE Table
    Set this back to stock.
    3. B3308: Disable DFCO: Change B3308 (M6) to 140C Change B3313 to 140C
    Accurate fueling computations
    If you want DFCO to activate, set these back to stock.
    4. B4105: O2 Switch-points to 450 Millivolts
    Smoother MAF & VE Table
    Leave this as is at 450 mV.
    5. B3618: PE Modifier Based on Rpm (EQ): 1.16
    Safe adequate Fueling regardless of Fuel Type
    Leave this as is (any value in the range EQR 1.160 to 1.175 is ok).
    6. B3616: PE Enable: make sure PE enables as load becomes significant
    (e.g. below 60% TP below 3200 rpm, 35% TP above 3200 rpm).
    Leave as is (you want PE to be readily available).
    7. B3608 and B3609: PE Delay: set these to zeros.
    Leave as is.
  2. #52
    And in the Tutorial:
    Additional Considerations:
    1. Table {B0120} “RPM Threshold For Airflow Calculation”:
    Change RPM Threshold to 400 RPM. This will eliminate the airflow correction that is
    applied from the VE Table B0101. The amount of airflow correction and its effects on
    LTFTs is complex. Most beginning users can leave the RPM Threshold at 4000 RPMs.
    Your LTFTs will update over time, so it is always best to perform additional Quality Control
    runs periodically.
    Set back to stock when finished tuning.
    2. Parameters {B3308} and {B3313} for Disabling DFCO:
    Set temperature to 140
  3. #53
    Dec 2013
    Perfect!
    Just what I needed.
    My widebands will hopefully arrive this week so I can give this a shot next weekend.
    Thanks again Joe!
  4. #54
    No worries.
  5. #55
    Dec 2013
    Well, as my luck would have it, my new WBO2s arrived on Friday and now the weather is too crappy to take the car out to get some logs (I won't take it out with salt on the roads). So it appears I'm in a holding pattern for a while.
    I did have a question on hooking up 2 WBO2s with Calc.Vet- Is it possible?
    Since it appears that I do have some differences (nothing too major) between the banks when looking at my fuel trims, does it make sense (or is it even possible) to look at both bank's WBO2s while running Calc.Vet?
    Just curious.
    Happy Holidays!
    Elm
  6. #56
    Yes, we can edit the calc_pids.txt file to use 2 widebands...
    I dynamically select the leanest wideband (i.e. I have a calc pid that selects the leanest lambda on-the-fly)...
    we can edit this into your calc_pids.txt file...
    connect your two 14POINT7 wideband to FSV2's AD1 and AD2.
  7. #57
    Dec 2013
    That would be outstanding!
    I will be building my WB logging wiring harness over the holidays so I can incorporate both WBO2s into the design.
    Thank you again Joe!
    I don't know where I would be without your advice and expertise.
    Elm
  8. #58
    I modified your calc_pids.txt (from post #46 above), see attached.
  9. #59
    Dec 2013
    Wow, that was FAST!
    This is excellent Joe, thank you SO much for doing this for me.
    I'll keep you posted when I can finally get some logging done.
    Elm
  10. #60
    no worries
  1. Auto to manual (tune)
    By K3vin in forum Tips and tricks
    Last Post: November 22nd, 2016, 09:58 AM
  2. manual switch for auto
    By smellyflange in forum General
    Last Post: August 4th, 2013, 05:59 PM
  3. auto to manual e38
    By dags in forum Gen IV V8 Specific
    Last Post: March 6th, 2010, 09:18 AM
  4. Conversion of Auto to manual.
    By odd boy in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 18th, 2009, 09:58 AM
  5. V4 License auto or manual
    By leibhold in forum Purchase and Shipping
    Last Post: November 26th, 2008, 05:54 PM
