Results 1 to 9 of 9
Thread: no power to flashscan
    Default no power to flashscan
    i was driving along my virtual dash on my lap top everthing was fine
    then it said unable to connect and now i have no lights on my black box
    also my dash lights did a quick blink i dont know what happened but i can not connect
    it was a fuse same one as cig lighter
    this has happened to me before just not with efilive, seems kinda common this fuse that blows.
    Senior Member Tydriver's Avatar
    Mar 2005
    You guys ROCK !! That was my problem as well in my '02 Silverado.. But why in the world does the cigarette lighter have anything to do with connectivity issues when its not even used on the Efilive or my laptop ?
    Todd
    1993 BMW 325is <- For Sale
    2003 Silverado LS 4x4 <--- you want to autocross what?
    2005 Avalanche 5.3L LS(EFI Live tuned) <-- my gas hog running on e85 3+ years now
    2012 Subaru Outback (wife's daily)
    the port you connect the flashscan to uses the same fuse as the cig lighter
    i was scanning and smoking at the same time hence blew my fuze
    Oct 2003
    Wouldn't it be safe to upgrade this fuse by 2.5 to 5 amps?
    I've had it blow on me once ...
    I'd rather be blown, bored... AND stroked!
    Now: 447 CID (Corvette 427) , ATI Procharger D-1SC Supercharger
    Oct 2005
    Safer to stop smoking
    2014 VF SV LS3 Maloo.
    Oct 2003
    Quote Originally Posted by ringram
    True ...
    It blew on me with an inverter in there .
    You know the funny thing is the SAE specifications for the J1962 OBDII 12V supply says that the connector must be capable of supplying 4 amps.
    SAE J1962 Section 6.3.11
    Vehicle connector terminal 16 is designated Unswitched Vehicle Battery Positive and must be implemented in the connector. This terminal must be connected directly (i.e., unswitched) to the DC positive of the vehicle's battery. This connection does not preclude the use of a fuse or other circuit protection elements. This circuit may be grouped with other similar circuits. This terminal must be able to supply a minimum of 4.0 A.
  1. No Power 6.0 5psi!
    By pandreas in forum Gen III V8 Specific
    Last Post: April 22nd, 2009, 04:14 AM
  2. no power in an l76
    By dynarex in forum E37, E38 & E67 PFI ECM's
    Last Post: April 21st, 2008, 11:54 PM
  3. Low power mode and power cycle?
    By SV8346 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 11:40 PM
  4. Where's the power????
    By ronhall512 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 22nd, 2006, 02:27 AM
