Results 1 to 10 of 10
Thread: LML Speed Limiter Removal
    May 2012
    Default LML Speed Limiter Removal
    Any update on when the speed limiter will be able to be removed on an LML. Have a customer with a 2013 wanting his gone.
    The tables are there to do it now, but, we've been informed that you might get a dead pedal after you lift above whatever the stock limiter is set to. We've been away for a month so not much has happened, but we will look further in to the speed limiter next year.
    May 2012
    I maxed out all the speed limiter tables I could find, no dead pedal but the truck still limits itself at 98mph
    Don't know if that could help, I changed/reduced the maximum speed to 100kph on my truck and that work ok. Change made to B2200,B2501,B2500,B2202. OP Sys 12645750, version 7.5.7 build 246 , 8.2.2 build 238
    Nov 2013
    i too tried to remove the limiter and it was a no go on my dyno
    Calibrator @ The Roadster Shop
    www.roadstershop.com
    It can be done, I know our beta guys stopped pestering us about it, that is a good sign
    Nov 2013
    thats good!!
    this guy wasn't needing it removed but on a few pulls we did hit a fuel cut at the same speed every time. He just wanted more mpg out of it and a a few more hp. I didnt even have to touch the fuel table (so his DIC would stay somewhat accurate) i just adjusted the tq limits timing and reduced the lambda a touch in the anti-smoke tables.
    Jan 2014
    Quote Originally Posted by computerjlt View Post
    thats good!!
    I've seen this mentioned before...
    so when the fuel tables are modded the DIC accuracy goes away? is there anything you can do with this?
    If you adjust the injection pulse time table I would think that would mess with the DIC accuracy, otherwise it should still calculate the fuel usage correctly if you are just altering the commanded torque tables.
    Jan 2014
    I guess I'll look at it some more. I need to learn tuning theory on these.
    What if you alter fuel pressure... Then the tq per pulse width will change...and screw everything up.. No?
  1. Speed limiter
    By RichardWebman in forum E37, E38 & E67 PFI ECM's
    Last Post: August 7th, 2009, 04:41 PM
  2. '06 LBZ speed limiter removal
    By JAY4SPEED in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 7th, 2007, 05:37 PM
  3. Removal of speed limiter
    By 06-6.0 SierraHD in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 20th, 2007, 04:49 PM
  4. 2001 Speed limiter removal works!
    By Trippin in forum Duramax LB7
    Last Post: March 12th, 2006, 12:15 PM
