Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 40
Thread: Analog wideband help for new starters
  1. #11
    BTW:
    analog connection is simple, it consist of connecting the signal wire and the return/ground wire between the wideband controller and FS;
    serial comms connection is also simple, it consists of connection a null-modem-serial-comms cable between the wideband controller and FS;
    in both cases you have to enable the appropriate pids (analog EXT.AD1 or serial EXT.WO2xxx1, in V8 Scan&Tune software goto Devices).
  2. #12
    Nov 2013
    Gday Joecar I'm using a haltech and a v2 fully up to date i be leave everything is wired up like you said that part is easy, but getting everything to talk is not at least not for someone new to efilive.
    Ive made a null modem connector and serial cord also as i bought the v2 second hand and it didn't come with the serial cord so Ive got everything for when the lc-2 arrives.
  3. #13
    Nov 2013
    Really keen to have a go at the calc.vet once i get everything working, is the process the same using calc.vet with a mafless cos.
  4. #14
    So you have the analog signal wire and the analog return/ground connected to your V2's AD1 + and - terminals respectively...?
    Go into V8 S&T, Goto Devices, goto BBL (Logging) tab, checkmark Automatically select all external analog pids, click Save, click Program, and then exit.
  5. #15
    Nov 2013
    Yeah wires are hooked up as you have said ill give it a go, for some reason i havnt been able to use the v8 bbl i can't work out how to select the pids then save like you do with the v7.
  6. #16
    Nov 2013
    it has showed up with a $0106 received data contained parameters that were out of range, ill try again does power have to be to the w/b ignition ON to do this?
  7. #17
    Nov 2013
    Tried it again just keeps coming up with the $0106
  8. #18
    Nov 2013
    Ok thats worked i was trying to save to the sd card not the internal memory, ill see if that allows the afr wideband to read on the v2 later tonight
  9. #19
    Nov 2013
    Still no afr reading from the wideband to the v2.
  10. #20
    Lifetime Member darcy's Avatar
    Feb 2012
    Are you using pass-through with v7.5 or BBL on the V2?
    The V2 can't display calculated pids, which AFR from an external voltage input is.
    Are you able to see external input voltages?
  1. Error $5 (analog wideband logging)
    By rumblebox in forum FlashScan V2
    Last Post: August 22nd, 2013, 05:07 AM
  2. Analog wideband install?????
    By T&A Custom Rides in forum General
    Last Post: January 30th, 2012, 08:52 PM
  3. Replies: 9
    Last Post: November 16th, 2011, 03:17 AM
  4. Autronic MAFM1 wideband analog to V2
    By APS Luis in forum External A/D inputs
    Last Post: July 10th, 2011, 02:30 PM
  5. Lost all wideband analog and serial pids
    By Wichita Dyno in forum General
    Last Post: August 23rd, 2010, 04:24 AM
