Results 1 to 3 of 3
Thread: Using the AC relay output to control a second fuel pump
    Apr 2010
    Default Using the AC relay output to control a second fuel pump
    Hi, Just wondering if anyone has used the AC relay output to control a second fuel pump depending on RPM or TPS? Looking at the wiring diagram and parameters in efilive it may be doable. Would have to use the NC contacts on a relay and have the "AC Disable RPM" or "AC Disable TPS" actually turn the pump on. Will probably have to bridge the AC transducer input also. I was considering using the shift light output but as my setup is an auto it is used for a shift solenoid.
    Dec 2007
    Quote Originally Posted by ttls1 View Post
    The AC on command comes via the CAN from the BCM. So might work with AC switched on .
    Apr 2010
    Cheers, I forgot to mention that this is in a conversion so I don't use the PCM for AC control. Also realised I should have posted under the genIII topic as its an LS1 ecu and it has an input on the pcm for AC request. Will try and give it a go
  1. fuel pump control
    By THEFERMANATOR in forum Duramax LB7
    Last Post: August 9th, 2013, 06:13 AM
  2. Replies: 15
    Last Post: May 6th, 2012, 03:20 PM
  3. Replies: 8
    Last Post: August 22nd, 2011, 12:08 PM
  4. Replies: 1
    Last Post: September 22nd, 2010, 03:40 AM
  5. fuel pump relay constantly switching
    By steve40 in forum Gen III V8 Specific
    Last Post: July 3rd, 2009, 02:32 PM
