Results 1 to 10 of 14
Thread: help with changeing WOT down shift pionts
    Senior Member restless@westnet.com.au's Avatar
    Aug 2008
    Default help with changeing WOT down shift pionts
    hi guys i would like to know which # to change to stop my A 6 from downshifting from 6th to 3RD at WOT at 120KMH
    thanks
Name:	WOT DOWN SHIFT PAGE.jpg
    Feb 2006
    none of them really. u need to adjust your part thottle shifts, then u match the wot tables to whatever your part throttle is set to.
    this is mine with 3.27 diff gears.
    that only allows mine to kick back to 4th. basically any speed below the 100%tps values will allow it to kick down a gear
    Aug 2008
    hi mate
    thanks for that i will compare it to mine and adjust it
    they can be a bit of a had full downshifting to 3rd at WOT at 120 KMH when you just want to pass some one on the highway hay
    Aug 2008
    im assuming all three part shit patterns are the same ???
    Feb 2006
    Quote Originally Posted by restless@westnet.com.au View Post
    hi mate
    I've never needed to use wot to pass a car in my ve.
    u only need to change the shift pattern that affects normal mode. if u want to do the same in sports etc up to u. I normally make my normal/cruise mode tables the same though.
    Aug 2008
    i know you don't need to go WOT to pass a car
    but its the only time i get to go WOT as we have no track here
    Aug 2008
    i copied all the settings you sent TREE COOL THANKS ,
    it still down shifts to 3RD at about 80% throttle at 100 kmh , so dident fix what i hoped it would
    , the other thing it does with your # is it stays in 5th till you hit 78kmh wont change to 6TH till 78 KMH
    which i find a bit annoying round town at 60/ 80Ks as its up and down 5TH/6th constantly,
    with the stock tune # it changes up to 6th at about 68 kmh
    can you explain to me the relevance of the # to speed like say its 80% > 99 > 3>4 does that mean it shouldn't down shift from 4 th to 3RD at any speed OVER 99 kmh ??? cant seam to grasp weathe i need higher # or lower # im happy with the drivability with stock tune #
    except i don't want it to downshift to 3RD at over about 85kms
    can you just change a few # in one column or do you have to do the whole column in rising % top to bottom
    thanks
    Lifetime Member darcy's Avatar
    Feb 2012
    Thats exactly what it means, Bob.
    I think of the table numbers differently in my head for up and down shifting, since upshift and downshift are usually activated by different usage of the throttle pedal.
    For upshifting, I think of it as sitting on a consistent throttle opening - then set the speed to shift at.
    For downshifting, I think of cruising along a a given speed and then increasing the throttle to make the box shift down. Enter this speed against the throtttle position you want to make the shift happen at.
    For UP-shift; Increaseing #s = more speed required before up-shifting for a given throttle opening (holds gears longer)
    for DOWN-shift; Increasing #s = less throttle required at any speed to make it down-shift
    Keep the highest number in the 4->3 column as 85.
    Aug 2008
    hi darcy
    thanks for the confirmation
    it does make me wounder way it doesn't seam to work in my case , as i have had the 4 th >3rd # down to 72kmh from 75% to 100% TPS it still drops to to 3RD on WOT ??
    is there some other setting that needs to be set along with the above ??
    Feb 2012
    It's probably the WOT tables overriding - as Dave mentioned, you need to set the WOT tables to match the part throttle tables. Set D1114 thru D1155 to the same as the 100% row of the 4>3 shift table.
    I'm not sure if you can just set D1251, D1250 to 100% to eliminate the WOT tables from being activated.
  1. when changeing rpm what all needs changeing ?
    By lstruck in forum Petrol / Gas
    Last Post: February 1st, 2013, 03:46 AM
  2. WOT shift points
    By andysc3 in forum FlashScan V1
    Last Post: March 12th, 2012, 01:22 PM
  3. WOT Shift, 1-2, 2-3
    By arubenstein in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 25th, 2008, 01:24 PM
  4. trans shift pionts?
    By JODAGR in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 5th, 2007, 09:15 AM
  5. Need help setting WOT 1-2 shift
    By 12secformula in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 15th, 2006, 09:39 AM
