Hi guys just wonder if any one may have some injector settings for bosch id2200 injectors on a ls1 controller I've got it dialed in OK at full noise but can't lean it out enough under 3500rpm fuel pressure is set at 50psi with boost reference
Hi, Are you using the bosch ones with this part number 0280158821?
Hi yep there the ones
ok - probably not helping much here, but thought I share this....
I was using these injectors (& I know a lot of others do as well). I am running a LSA with a vortech s/c. Had an issue leaning out & discovered the injector flow rate had dropped by almost half. Went to Bosch to ask about these injectors & was told "The injector you are using is not approved by Bosch for use with ANY liquid fuels, particularly alcohol based. Injector 0 280 158 821 is part of a family of injectors know as NGI2 which are solely designed for compressed natural gas (CNG) applications".
I was also sent the attached product bulletin (hopefully I've attached correctly).
Like I say, this doesn't help with your original question - just thought I'd share.
Can you point me to where you got that pdf...?
By coincidence, I'm tuning a CNG engine and need more info on the CNG injectors.
Hi Joe,
Sure - Raphael.Mudge@au.bosch.com
Hi yep funny you say that I had the 1650 versions and had heaps of trouble with them afrs always changing etc but in saying that I very fitted them to another vehicle with no known problems different fuel I was running meth and just assumed I'd stuffed the injectors with the meth so I changed to e85 and went the 2200s haven't had problems at full noise but it's pig rich under 3000rpm
Sorry to correct myself I fitted the same part number injectors to the other vehicle what injectors are other people running to surport 1200hp
