Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 51
Thread: 4l80e upshifting when held in gear
  1. #31
    Taz has a good point... if VE table is close then trans line pressure will be closer to matching engine torque.
  2. #32
    Lifetime Member EagleMark's Avatar
    Dec 2010
    Try this (attached).
    You have a shift kit, and you're seeing soft shifts...? If you still get soft shifts with the attached file, then try setting the shift times tables to 0.2 seconds all across.
    ^^ Read above^^ He said set table to! Not add to!
    Quote Originally Posted by tdmkr496 View Post
    I tried your file and it still didn't seem to shift that hard so I went ahead and added the .2 to all three shifts. Should I go up more? The 1-2 seems slightly better, but the 2-3 is still sluggish. The trans is a fresh rebuild, and I had him put a Trans Go HD-2 shift kit in. It shifted great when I first started driving it (about a month ago) and slowly has gotten worse. I really appreciate you guys helping me!
    "Slowly gotten worse" is a sign the adaptive learn is working against the shift kit. When you added .2 you made it worse for learn.
    Although this thread was for 4L60E I think a lot of it will help understand, it did to me when I started it. Also look at first post! I linked all really good threads on transmission tuning.
    HTH!
  3. #33
    Dec 2010
    Forgot to add the link and having issues with "Edit Post" so here's the link:
    http://forum.efilive.com/showthread....ock-3rd-at-WOT
  4. #34
    Aug 2010
    Quote Originally Posted by EagleMark View Post
    ..."Slowly gotten worse" is a sign the adaptive learn is working against the shift kit. When you added .2 you made it worse for learn ...
    As long as there is no concurrent mechanical issue, then you are probably right on the money. I always disable the Low Pressure Adjust (to keep the PCM from reducing pressures), but keep the High Pressure Adjust active (more pressure is rarely a bad thing).
  5. #35
    Jul 2013
    How do you disable the Low pressure adjust, zero out all the values?
  6. #36
    Jul 2013
    HTH!
    I typed it wrong, I set to, not added to lol. I will set them back to 0.0
  7. #37
    Aug 2010
    Yes.
    Try the attached tune ... use caution. Without knowing how much the fluid flow / pressure was increased mechanically by the shift kit, I am merely guessing at a starting point. The attached tune could end up being extremely harsh and unusable, or fairly close for drag strip use.
    I also put some torque reduction back in, just to be safe.
    This tune is intended as a starting point for developing desired shift firmness. It will not hold first gear if manually selected (no stock 4L80 tune will) - I charge a fee for that service - if that is something that you may need down the road, just send me a PM.
  8. #38
    Jul 2013
    Thank you for all of your help but it looks like the pressure control solenoid is bad. I have one on the way, I'll let you guys know as soon as I get it back running.
  9. #39
    Senior Member Wolfie's Avatar
    Dec 2007
    At the risk of coming across like a dummy (yeah, I've been called that) I have forgotten much more that I probably will learn since I've kinda parked my van,
    I'm assuming that it doesn't really hurt the tranny to add in lots of base pressure (D0701,D0702, D0703)? Mine seems to me to shift really soft, even with disabling torque reduction, and zeroing out the desired shift times.
    Wolfie
    LS1B 2007 Express 6.0 /w 470,000+ miles (parked as of 01April2011)
  10. #40
    Aug 2010
    Hi Wolfie ... I can email you one to try if you want ... the one I posted in this thread is far too harsh for a daily driver to use !
    To answer your question, you can add quite a lot of pressure to the 3>4, a fair amount of pressure to the 2>3 shift, and a cautious amount of pressure to the 1>2 shift.
    With a vehicle like yours, with an active Tow/Haul switch - two separate profiles can be developed. One for daily driving, and the other for towing, drag strip, etc.
    Taz
  1. 4l80e parameters to prevent TCC from disengaging in 4th gear
    By GMCtrk in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 9th, 2020, 08:55 PM
  2. Why does 1st gear slam into 2nd? 4L80E translplant
    By 1SlowHoe in forum Gen III V8 Specific
    Last Post: May 22nd, 2010, 09:47 AM
  3. manual gear selection overide 4l80e
    By 2500ak in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 6th, 2010, 04:48 PM
  4. 4L80E 2nd & 3rd gear only
    By rickwils51 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 1st, 2007, 06:06 AM
  5. 4L80E 4rth Gear problem
    By almusafir in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 14th, 2007, 02:43 AM
