Originally Posted by
12_Square
Okay, I have another variable here... I checked my fuel pressure. Initial pump prime makes the pressure jump to 64psi, then the line holds steady at 50psi (engine off.) With engine running it's steady at 64psi. Car has a 255lpg Walbro fuel pump and has been running with the stock '98 IFR table. The new injectors I'm working with now are 187g/min at 300kPa as rated by Bosch.
55 to 60psi is what the genuine GM manual specifies, but can I make it all work with the current pump, or is it better to buy a new one within the OEM range? (Or is there something wrong with the aftermarket one?) I do not run any kind of boost and never will on this car.
