Results 1 to 4 of 4
Thread: LM-1 logging/map issue
    Nov 2006
    Default LM-1 logging/map issue
    I'm using an LM-1 and trying to use the AutoVE maps to tune VE on a 2001 5.3.
    First time i've used efilive for tuning.
    My wideband is reading (hooked up via serial) but the map is attempting to use WB02AFR2 and my LM-1 seems to be reading on WB02AFR1 pid.
    WB02AFR2 is reading 25.00 thru the whole log,and can't seem to figure out how to change it in the map.
    The map averages are just showing 25.00 in all the cells i'm hitting.
    I'm using the preloaded maps and PIDS with flashscan V2 and V7.5 (fresh download due to possibly overwriting pid lists,WB issue was before this though).
    Any help?
    Nov 2006
    sorry,think I found it.
    Kept trying to change the map and finally gave up cause my pid wasn't in the list.
    Decided to look again and go figure now it's in there and my data went to what I needed so think problem solved.
    Did you figure it out...?
    What pid are you using in the Data tab in the map...?
    Post screenshots.
    Also, see the Calc.VET thread, you can use the pid CALC.WO2BEN to perform AutoVE (requires copying the calc_pids.txt from that thread).
  1. GM 12592525 Map Issue
    By Webbs in forum Gen IV V8 Specific
    Last Post: June 2nd, 2013, 09:18 PM
  2. building a map when logging
    By triton in forum Cummins 5.9L
    Last Post: January 7th, 2012, 06:31 AM
  3. Ve map logging help
    By TBMSport in forum Gen IV V8 Specific
    Last Post: July 8th, 2011, 07:09 AM
  4. map sensor issue?
    By SGFastMax in forum Gen III V8 Specific
    Last Post: May 2nd, 2009, 03:53 AM
