Results 1 to 10 of 17
Thread: Maf scaling
    Aug 2012
    Default Maf scaling
    I searched and was surprised I didn't find anything in the search?
    If I wanted to install a LS7 Slot Style Maf into a Camaro/Trans Am with 0411 PCM, how would i properly re-scale the Gen4 Maf to work properly in EFILive? If this is all ready a write up somewhere can someone post a link to said write up, Please?
    thanks guys.
    You would have to correct the MAF table by doing AutoMAF or Calc.VET using a wideband.
    Aug 2012
    I wouldnt have to rescale the HZ load, just tune the curve like normal?
    If you can interpolate the Hz scale to fit the LS1 MAF table (requires some math software), then go ahead and do it, but you'll still need to correct/tune it
    ( the main reason being that your MAF plumbing has it's own characteristics which are different from other vehicles, and which usually will affect how the MAF behaves )
    Id use the f-body IAT sensor, the LS7 one has a different scaling and EFILive IIRC doesnt have the IAT scaler table to change it.
    Erik makes a good point.
    Aug 2012
    Good to know!! thanks guys.
    Sep 2012
    I had to scale the LS7 MAF on my turbo 98 TA....but it was the entire tune that had to be scaled, not just the MAF.
    Jul 2005
    is there an automaf tutorial?
    Quote Originally Posted by steve40 View Post
    You do this:
    - disable VE (set B0120 to zero).
    - disable CL/LTFT/STFT (B3801, B4205, B4206), and SOL if you're running a COS (B3647, B3649).
    - set PE safely rich (B3618), and make sure it enables suitably (B3616) .
    - log wideband lambda.
    - create MAF map of BEN (e.g. BEN pid = "{EXT.WO2LAM1}*{GM.EQIVRATIO}").
    - apply low cell count filter and throttle transient filter.
    - multiply BEN map into MAF table B5001.
    - extrapolate/smooth B5001 to cover un-hit portions of table (should look look like x^4 polynomial curve).
  1. Scaling MAF for Supercharged GM LS1
    By RamAir in forum Gen III V8 Specific
    Last Post: January 8th, 2013, 02:21 PM
  2. 2012 CTSV Maf scaling, open loop issues.
    By ditosmotors in forum E37, E38 & E67 PFI ECM's
    Last Post: June 27th, 2012, 02:37 PM
  3. Why reduce MAF scaling values on a basically stock E38?
    Last Post: June 24th, 2011, 11:44 AM
  4. Replies: 10
    Last Post: August 27th, 2009, 10:38 AM
  5. VE Scaling
    By SS2win in forum General (Petrol, Gas, Ethanol)
    Last Post: October 13th, 2005, 07:14 AM
