Results 1 to 3 of 3
Thread: NO Pilot, No Post help!
    Jan 2014
    Default NO Pilot, No Post help!
    I made this no pilot and no post injectioin tune and im pretty happy with. i was wanting to have someone look over and see if they can see why theres a small hicup when feathering the pedal from a complete stop at 1000-1100 rpms during going from 1st to 2nd auto trans. It also blows a puff of white smoke then clears up at 1200 rpms and only does it from a stop. could it be bec of the retard of timing during shift? ive tried to play with it and have had no luck maybe some one can chime in with a little help?
    09 6.7 cummins, egr,ccf,dpf,cat delete. efi by me....
    Nov 2010
    Not enough main timing.
    Id rethink your pulse table as well....
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    I agree with Les, no way you are even coming close to maintaining rail with that much duration. If you have the pumps to allow you to maintain, you will melt it down.
    Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
    EFI Live Cummins Beta Tester
    Duramax and Cummins Tuning
    423-506-7427
  1. LBZ Pilot and Post show up in log?
    By Drake_Lawdawg in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 13th, 2013, 09:48 AM
  2. Pilot vs No Pilot Main Pulse Map
    By brossjd in forum Duramax LLY
    Last Post: August 7th, 2012, 10:41 AM
  3. Post Injection Problem - DPF Delete enabled, Post Inj #2 still squirting!
    By dmaxhumvee in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 22nd, 2012, 03:28 AM
  4. Help with pilot timing
    By AdamRRT in forum Cummins 5.9L
    Last Post: January 6th, 2012, 10:07 AM
  5. Replies: 4
    Last Post: January 2nd, 2012, 08:24 AM
