Results 1 to 5 of 5
Thread: Ethanol Sensor on MAF circuit LS1
    Lifetime Member macca_779's Avatar
    Jan 2007
    Default Ethanol Sensor on MAF circuit LS1
    Guys I have a theory id like to put past the brains trust
    What's everyone's thoughts on using the GM ethanol sensor on an Ls1 by inputting the frequency signal into the MAF circuit which is unused in an SD application
    You would then creat a calc pid to interpret the 50-150hz signal
    If you feed a signal in there it will be used again (by the airflow calculations), Mmm, actually if you set the high fail to 20Hz it should stop looking at the signal.
    And is this just for monitoring ethanol % ?
    Need official EFILive help, please go here.
    For tuning support please post your questions on this forum (or other auto forums).
    Sorry if I don't respond to your PM, don't take it personal.
    Jan 2007
    That's the theory. The plan is just for scanning. (Unless you guys want to revisit 0411 development hint hint). But yeah anyway saves installing an extra gauge when you could just use the V2.
    I've been told the MAF starts at 1.5khz. But will the PCM still read a lower frequency?
    Quote Originally Posted by macca_779 View Post
    Ahhh, no, pretty unlikely, sorry.
    Actually I have no idea, maybe the other option is to look at other manufacturers who do FlexFuel and see what they use, one of them might be a 0 to 5V signal.
    Feb 2006
    zeitronix can output a 0-5v signal from an flex fuel sensor.
  1. Knock sensor circuit low signal...
    By VTC_WS6 in forum Gen III V8 Specific
    Last Post: July 13th, 2013, 06:58 PM
  2. Tuning Around a MAF Sensor
    By WisconsinHick1 in forum Duramax LLY
    Last Post: May 6th, 2013, 02:50 PM
  3. Ethanol questions - converting non-flex fuel to ethanol
    By BLK02WS6 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 5th, 2012, 07:15 PM
  4. Auxillary ect sensor/efan circuit
    By johnmaster in forum Gen IV V8 Specific
    Last Post: June 27th, 2011, 03:08 AM
  5. Problem with DTC PO342 Camshaft Position sensor circuit low
    By LSXstart in forum Gen III V8 Specific
    Last Post: December 3rd, 2010, 03:35 PM
