Results 1 to 7 of 7
Thread: Stock LGH tune needed OS 12646249
    Default Stock LGH tune needed OS 12646249
    Looking for some stock LGH files for a 2011 cab/chassis. No luck on the 4shared site yet.
    See pic thanks
Name:	2011 LGH cal.png
    04 LB7
    2010 LMM
    2015 LML
    New Member cokane1's Avatar
    Nov 2013
    2011 GMC DENALI LML - 4" AFE EXHAUST - AFE INTAKE - FASS TITANIUM 150GPH - 33X12.5X20 MICKEY THOMPSON BAJA ATZ - AMP POWER STEPS
    EFI LIVE BY KORY WILLIS / PPEI 461RWHP & 865FT/LBS TQ (11-16-13) STOCK FUEL AND TURBO
    MCC BY COKANE 499.7RWHP & 895FT/LBS TQ STOCK FUEL AND TURBO (11-16-13)
    Thanks Chris this is the closest one so far, does it matter that not all segments are the same? The ones that don't match up per the TIS website are Speedometer, System, Fuel System, and Engine diagnostic. What problems could there be, the speedo and fuel system ones should be easily changed but not sure about the others?
    Edit: Would more info help like 3500, 4x4, single rear tire, extended cab, 34/36 gallon fuel tank, power windows/door locks, air conditioning?
    04 LB7
    2010 LMM
    2015 LML
    I had an LGH file sent in to check out as it looked like one of the tables had a serious problem, but as it turns out I think it is ok, I triple checked it.
    Unfortunately I am also out of the office until the end of December so I can't Email it to you.
    Ok thanks Ross, also how important is it for all the segments to match in the tune files? I remember it was a big deal on the LB7-LLY but didn't seam quit as important on the LBZ/LMM. Is it pretty close as long as it comes from another LGH with the same main operating system?
    04 LB7
    2010 LMM
    2015 LML
    Nov 2005
    Quote Originally Posted by rcr1978 View Post
    Well I guess the answer to that question depends how you define important.
    Some people will tell you you can tune every LML on less than a handful of files, and others complain in that instance of features not working....
    Cindy
    Did anyone find anymore tunes, I still have not found one of these?
    04 LB7
    2010 LMM
    2015 LML
  1. Replies: 6
    Last Post: October 23rd, 2013, 04:27 PM
  2. Replies: 10
    Last Post: July 7th, 2012, 07:52 AM
  3. Stock ZR-1 Tune?
    By arubenstein in forum E37, E38 & E67 PFI ECM's
    Last Post: March 27th, 2011, 12:22 PM
  4. Lml / lgh
    By shay in forum Duramax 2011+ LML / LGH
    Last Post: March 10th, 2011, 01:41 PM
  5. Help: Stock tune please
    By doubledip in forum General (Petrol, Gas, Ethanol)
    Last Post: September 7th, 2010, 02:14 PM
