Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Anyone have a NTK AFX calc pid for E85?
  1. #11
    Nov 2006
    *CLC-00-027
    lambda 0.00 1.60 .3 "({EXT.AD1}*0.096)+0.62"
    CALC.LAM_NGK1 F027 CLC-00-027 lambda WO2-Analog "Wide Band Lambda 1 - NGK
    AFX"
    you will need to make a calc.pid based off the Lambda range & the stoich AFR value of E85.
    for 9.4:1 AFR
    ({EXT.AD} * 0.9024) + 5.828
    resolution will be reduced by .5 AFR
    and the AFX gauge will still display 14.57 when lambda = 1.00
    e85 = 9.7:1?
    LC-1 WBO2
  2. #12
    Post tune file and log files.
    You can sanity check your wideband by seeing what it reports while CL/LTFT trimming is going on.
  1. NTK AFX Wiring and PID Advice Needed
    By 12_Square in forum External A/D inputs
    Last Post: January 23rd, 2014, 04:30 PM
  2. need help with e85 pid
    By Big Block in forum Gen III V8 Specific
    Last Post: March 3rd, 2013, 05:22 AM
  3. calc.pid help
    By mr.prick in forum General
    Last Post: June 1st, 2010, 01:28 AM
  4. Custom PID's for different fuels I.E E10 & E85
    Last Post: April 11th, 2010, 06:21 PM
  5. e38 dma pid SCALEDCORVE_ doesnt work plus a bad calc pid
    By ringram in forum FlashScan V2 BB Logging
    Last Post: November 30th, 2008, 10:28 AM
