Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Help me select a COS
    Quote Originally Posted by Hambone View Post
    Ok, got 12212156 to full-flash in, then was not able to put COS5 (02020005) in after that. keep getting
    15:52:18.759: Unknown reply from boot loader: $FE.
    15:52:18.775: PCM is in an unknown state.
    Tried multiple times, of course, both with and without "Recover PCM" checked. No dice.
    I have an idea how to do it now, and the process is failing me. What would cause this message? Luckily, my original OS went back in, seems to be just as it was, no problems.
    Do I have the wrong COS?
    Re-do the full flash of 12212156 into the PCM... what vehicle/year/model is this on...? Depending on the answer you might have to disable some of the modules on the bus.
    Aug 2010
    You seem a little confused about the COS process ...
    The COS is just that - a Custom Operating System ... think of it as an OS (like 12212156) devoid of a calibration - a blank slate. Once you get the COS flashed in (full flash), then you follow that up with a calibration only flash of your base calibration. If you need a 4L80 transmission - this is done in the base calibration prior to flashing it into the COS.
    Do I have an older, pre-release version of 02020005? If someone has a version that's already populated, and with a 4L80E, that would be extremely helpful.
    No, you have the correct one (what is the software build version of your installed V7 software (do Help->About in the scantool or the tunetool)).
    Yes, exactly as Taz said.
    The steps are as follows:
    - full flash in 12212156 containing 4L80E segment, and make sure engine/trans run correctly.
    - full flash in 02020005;
    - cal flash the 12212156 file;
    - fix all out-of-range cells (as explained in the COS5.txt document);
    - populate table B3647 and the Axxxx tables (see COS5.txt);
    - engine/trans should run correctly (at least same as first step above).
    Do not change trans segment after upgrading to COS.
    Jun 2012
    I'm running V7.5.7 Build 245. I updated it just a few weeks ago.
    I understand I need to fill the new COS with data, as its all blank, the issue now is I can't seem to successfully full-flash the blank COS for some reason. It says the flash failed, and gives an error $FE. I see now in another thread, that may be just a glitch, and it actually does flash correctly. Tomorrow will push forward, assuming the error message is wrong, and see what happens.
    See the text log that appears when you do a flash...?
    Paste it here.
    Jun 2012
    Paste it here.
    Ok, will grab it first thing tomorrow, not with the truck at the moment.
    Jun 2012
    Went out to grab the text log, and just for fun, ran V7 as an Administrator.....and it WORKED ON THE FIRST TRY!! Why wouldn't that be the most important and reiterated step in the entire process?! WTF?
  9. #19
    OK, that's the solution (EFILive writes the PCM serial number and license to a file in a system directory (Program Files\EFILive\V7.5\) whenever you go to flash, and without Admin privileges EFILive could not write the file).
  1. What PIDS should I select?
    By LM7Tuner in forum General (Petrol, Gas, Ethanol)
    Last Post: September 22nd, 2009, 08:33 AM
  2. Can't select RAFIG PID's in either BBL or Scan tool!
    By kwhiteside in forum Gen III V8 Specific
    Last Post: July 22nd, 2009, 02:53 PM
  3. cant select pids ini not found error message
    By Gelf VXR in forum FlashScan V2 BB Logging
    Last Post: September 3rd, 2008, 12:02 PM
  4. Cylinder Select?
    By WopOnTour in forum Tips and tricks
    Last Post: May 31st, 2005, 12:02 PM
