I just installed LT headers, no cats, Z06 manifold and a 224* 112* 0.580" cam. The idle speed is about 750 RPM and lumpy with engine rock. In the Scan program 850 to 900 RPM was an improvement.
In the car, with Tune, I down loaded my current PCM calibration, opened the file and opened idle, desired idle speed. The window has four columns, the two on the right were all zero and looked like the correct ones for my 6mn. I inserted 900 RPM for the current OAT.and interpolated for the seasonal temperature range where I live. Since I lost control of the fans due to the overheat warning yesterday with the old EFI program, I also reprogrammed the fans. I changed the #1 fan on to 184*F and off to 194*, #2194 & 185* since I have a 160* thermostat. There are many choices in the fans column, I only changed the on and off of 1 and 2. Is this correct?
I Programed the PCM with the changes with a "Test" first then programed. The fans now come on at the temperatures I changed to, but the Idle didn't seem to change to 900 although it was slightly higher. Should I try the idle with Scan as on page 130 to see what works and then go back to Tune with the results? I've read the other idle threads and may try the "jfpilla" method when I get more experience. Please, am I on the right track, mistakes??? what else can I do?
Thanks, Curt
