Page 1 of 8 123 ... LastLast
Results 1 to 10 of 76
Thread: Cal links.txt
    Jul 2007
    Default Cal links.txt
    Where does EFI LIVE 7.5 expect to find this file on disk? It appears as if the file is not found or not being used.
    I have used the RR endlessly without problem, but today I was trying to autotune my VE table with
    RR. I was able to log both MAP and RPM, but my BEN variable, which I call CALC.WB_VE_ADJ is not showing up in the RR box and thus no changes are made to VE.
    07 Silverado DMax Classic
    02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
    Old Engine: 1/4mile = 9.6/146 New Engine:?
    EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
    COS5/12212156 For 2002 Z06 Manual Vette
    Jul 2007
    Ok, I think I figured it out. Good ol search routine.
    The new cal link files have filenames like this: LS1B_Link.ini, E38_Link.ini, E40_Link.ini...
    Jul 2007
    Thank you sir. VE tune up in 30 minutes. : )
    Jul 2007
    at tuning shop. file not in update 245.
    Jul 2007
    UPDATE!!!!!!!!!! I found it AND working.
    ( in Program Files\EFILive\V7.5\Configuration )
    Ok, cool
    Nov 2005
    I know you've found it, but this is a link to what was changed, why, and when if your interested.
    http://www.efilive.com/latest/cat/ne...inking-change/
    Cheers
    Cindy
    Feb 2014
    I cant find these files or know where to put and use them , seems there really isnt one good tutorial on the RR from start to finish just alot of filler and in between stuff , this isnt a punch in the face but for 900 bucks there should be some better info in the FAQ see you soon joecar
    Feb 2014
    is this the file ??? and what do I do with it ???
    this was a good write up but left this out http://www.performancetrucks.net/for...runner-515906/
  1. Collecting links to scattered material...
    By joecar in forum Tutorials
    Last Post: March 31st, 2021, 11:39 AM
  2. sae_generic.txt
    By critter in forum Petrol / Gas
    Last Post: November 5th, 2012, 02:24 AM
  3. New Options.txt
    By Cougar281 in forum FlashScan V2
    Last Post: October 22nd, 2008, 07:52 AM
  4. Links to software suggestions...
    By joecar in forum General (Petrol, Gas, Ethanol)
    Last Post: May 22nd, 2006, 02:52 AM
  5. Links to widebands that will work with Flashscan/EFIL please
    By DebianDog in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2004, 04:22 PM
