Page 8 of 8 FirstFirst ... 678
Results 71 to 76 of 76
Thread: Cal links.txt
  1. #71
    Feb 2014
    iI found a weird problem which is two fold , first all software and pids for scanner are in imperial , but trying t do ve I have to switch map to metric for it to work and I tried this on several computers . second i have one computer that is correctly licensed for RR and efi and it stays in demo and the splitter doesn't work correctly scanner drops out about every two minutes , and im curious what else besides ve and or boost tables I can run and correct with RR , Joe we need a write up , a complete one I know Im new but I will help get it started ,maybe we can pull all of the good info of the threads and put those together and finish it , It would free you and others up alot to help with other issues
  2. #72
    setting units to Metric in scantool:
    - goto PIDs tab,
    - click twice on column heading "Units" (sorts the pid list on that column),
    - scroll down until you see a group of pids with units "kPa,PSI",
    - highlight that group of pids (click on the first one, hold SHIFT, click on last one, release SHIFT),
    - on the highlighted pids do rightclick->Metric (the Default column will now say Metric.
    setting units to Metric in the scantool maps:
    - choose a map (click the map's letter tab),
    - goto the map properties,
    - on each of the Data, Row and Column tabs select the Metric variant of the pid of interest,
    - remember to checkmark "Show Units" on each tab,
    - remember to save the map.
  3. #73
    On PC where EFILive V7 software says Demo mode, go Help->Register EFILive copy the blue card details exactly (the date field is non-US style)...
    also enter your RR serial number;
    i.e. see attached:
Name:	EFILive License.png
    Click Ok.
    And then copy the file \My Documents\EFILive\V7.5\User Configuration\License.txt to all your PC's.
  4. #74
    Are you using the old USB driver...?
    Start->All Programs->EFILive->V8->EFILive USB Manager, and install 2.02.04.
  5. #75
    Feb 2014
    so I should set the scan tool and the tune tool to all metric ? and yes the driver is updated , but why when im set to imperial everywhere do iz need to set map to metric ? its boggling my mind
  6. #76
    It will be easiest to set everything to Metric.
    In the map properties, an available pid will have two variants: Metric (e.g. SAE.MAP.kPa) and Imperial (SAE.MAP.psi)... choose the Metric variant.
  1. Collecting links to scattered material...
    By joecar in forum Tutorials
    Last Post: March 31st, 2021, 11:39 AM
  2. sae_generic.txt
    By critter in forum Petrol / Gas
    Last Post: November 5th, 2012, 02:24 AM
  3. New Options.txt
    By Cougar281 in forum FlashScan V2
    Last Post: October 22nd, 2008, 07:52 AM
  4. Links to software suggestions...
    By joecar in forum General (Petrol, Gas, Ethanol)
    Last Post: May 22nd, 2006, 02:52 AM
  5. Links to widebands that will work with Flashscan/EFIL please
    By DebianDog in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2004, 04:22 PM
