Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 76
Thread: Cal links.txt
  1. #21
    Feb 2014
    Actually i dont Click image for larger version.
  2. #22
    Feb 2014
ID:	16873 software version
  3. #23
    Feb 2014
    Sorry for the double post
  4. #24
    Nov 2005
    Quote Originally Posted by SW1911 View Post
    Its in your screen shot - LS1_Link
    Cheers
    Cindy
  5. #25
    Feb 2014
    could my pid list be wrong ? or is that even possible , when rr is active it scans cells like in my ve but there is no name in the right corner
    thanks for chiming in cindy
    jim
  6. #26
    Feb 2014
    also I should add im on a splitter for the usb , when i bought the RR they said that wasnt a problem
  7. #27
    Feb 2014
    this shows RR active and counting cells without changes because i dont know and cant find in ant search for days on how to link the calc txt files to the Rr, im stuck
  8. #28
    Several things:
    in the tunetool use kPa for the MAP axis;
    in the scantool select Metric units for MAP;
    in the scantool what BEN pid are you logging (if you have serial comms from your wideband, then this pid will be CALC.WO2BEN)...?
  9. #29
    Feb 2014
    i dont know joe , maybe tackling two new tools at one time isnt a good combo , I think im close and fail ,,, I really do not like the fact that there isnt a complete write up on a sophisticated tool as this even the setup takes an act of congress ,and no documentation from moates ,sent them an email and I feel like they made me out to be an idiot anyway i used this pid at someones comment about matching my aem up ,, very frustrated at this point ,,,and i dont see a linK_map anywhere so im stuck on rpm only at 15 kpa with no correction
  10. #30
    Oct 2006
    As Joe stated before. Ensure that both the tune tool & scan tool are using the same units.
    The Tremor at AIR
  1. Collecting links to scattered material...
    By joecar in forum Tutorials
    Last Post: March 31st, 2021, 11:39 AM
  2. sae_generic.txt
    By critter in forum Petrol / Gas
    Last Post: November 5th, 2012, 02:24 AM
  3. New Options.txt
    By Cougar281 in forum FlashScan V2
    Last Post: October 22nd, 2008, 07:52 AM
  4. Links to software suggestions...
    By joecar in forum General (Petrol, Gas, Ethanol)
    Last Post: May 22nd, 2006, 02:52 AM
  5. Links to widebands that will work with Flashscan/EFIL please
    By DebianDog in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2004, 04:22 PM
