Im still learning, thats why i need help.
I did an engine swap on a 2005 Jeep JK , i installed a 6.2L with a 6L80E..
Engine is working fine and transmission too..
But in WOT the timing stays betwen 2-17 degrees and even negative numbers, but it isnt nocking, i modify some tables to check if it was retarding timing but i havent had any luck, can someone take alook on the tune and the log and help me please
The stock tunes from the files i atached are on tunefiledepot
