Results 1 to 4 of 4
Thread: key fob programming via efilive?
    Apr 2007
    Default key fob programming via efilive?
    Vehicle: 2005 Chevy Equinox LT AWD
    I don't have either key fob as this is a recently purchased used vehicle. Is it possible to avoid the $60 dealer charge for programming? Can EFIlive do it?
    Jesse
    2003 GMC Sierra Denali
    6.0L, LQ4, AWD, 4WS
    Volant CAI w/ Scoop
    '06 Silverado E-Fans
    High Flow Cats
    Volant Cat-back
    Morimoto HID full retrofit /w all on mod
    All exterior lights LED (VLEDS) (except headlamps)
    LT285/70R17 Open Country AT II's
    Future: skyjacker 3" lift w/ rear add a leaf(hopefully)
    Key fob programming is done with BCM... EFILive only does PCM/ECM/TCM.
    I know with the TrailBlazers all you need to do is follow a simple procedure, no scan tool needed to program a fresh fob to the vehicle.
    Jul 2014
    Equinox requires a tech 2 to program key fobs. Dealer is you only option unless you have a buddy with one.
  1. liscense key
    By GCSPRING in forum EFILive V4
    Last Post: April 25th, 2013, 08:02 AM
  2. Key FOB Programming
    By check.47 in forum Diesel
    Last Post: March 20th, 2013, 02:11 PM
  3. TIS/SPS programming through EFILive?
    By Overkill in forum E37, E38 & E67 PFI ECM's
    Last Post: July 19th, 2011, 10:13 AM
