I have the injector sheet for these siemen-deka 80lb injector. Its mostly all greek to me since the numbers don't go with what efilive has or im lacking the formula to covert them. I have this one injector voltage offset. I have the numbers for voltage like 6v is 2.811 offset, 8v is 1.77 offset. where do I put it in at cause the row is manifold vacuum(psi). Do I put these number in the 0 psi one. Is so how would I go about getting the rows setup? Also the row name is alittle weird to me is this for pressure above atmosphere?
I have a tune for the siemen motron 80lb but I don't know if they are the same or not. Looking at that data it becomes even more confusing lol.
I know some of this is guess work but how would I go about making the corrections based off logs?
