Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: LS9 with trailblazer SS E67 cal
    Nov 2005
    Default LS9 with trailblazer SS E67 cal
    Hi everyone....got a couple questions.
    Background on the project:
    2006 SSR with a GM Performance Parts LS9 swapped in.
    Originally the shop that did the swap got it running with the GMPP E67 setup as standalone. But obviously none of the Class 2 stuff worked (instrument cluster, AC, etc). So the shop contacted someone at GM engineering to "turn on" Class 2 comms in the calibration so the gauges would work. Although there were still some issues.... GM engineering refused to enable cruise control, ABS/traction control PWM signal wires, and a couple other little things due to reasons of liability. And even though GM engineering enabled Class 2 comms, the PRND321 indicator still didn't work right. P, R, N worked....but D, 3, 2, 1 just made the display go blank.
    And the speedometer was a little off. And couldn't be fixed with EFILive or HPT because that table wasn't mapped out in the GMPP OS.
    So the shop contacted me to see if I could contribute any additional knowledge/advice since I have a decent background in the GM truck/SUV electrical systems, ABS, chassis controls, etc.
    So heres what I came up with and have been working on the past couple days:
    Swapped out the GMPP E67 LS9 calibration with a 2008 trailblazer SS E67 LS2 calibration. That fixed the traction control (although its still setting a C0279 incorrect powertrain configuration DTC, still working on that), PRND321 display, and will allow cruise to work once I add the additional wiring to the GMPP LS9 harness.
    I had to do a little re-pinning of the GMPP LS9 harness to work with the trailblazer SS calibration, but its pretty much good to go now.
    BUT obviously the TBSS E67 cal is setup for N/A, and the LS9 is supercharged obviously. And for some semi-annoying reason, EFILive has B8027, B8028, B8029 grayed out so I cant "enable" the supercharger stuff. HOWEVER. HP Tuners doesn't have those tables grayed out...you can change them.
    So I read the calibration out with HP Tuners, changed the supercharger stuff to "YES", flashed it back in with HPT, read the calibration back out with EFILive, and sure enough, now B8027-B8029 now read "YES"...perfect, I think?
    I also copied all of the GMPP LS9 calibration fuel, spark, etc, tables into the TBSS calibration, so the engine will run properly.
    But since the 08 TBSS has a mechanical fan, now the E-fan had no control because its disabled in the TBSS cal.
    SO...I went to PCM of NC website and found the patched EFILive file for e-fans enabled. Flashed that in, read the tune out with HPT, enabled supercharger stuff, flashed with HPT, then read out with EFILive, copied all the LS9 tables into the e-fan and supercharger patched EFILive file, flashed that in....and FINALLY....now I have an 08 TBSS calibration in there with e-fans ON, supercharger stuff ON, and LS9 tables copied in there.
    WOW...that was a PITA. But its working.
    The question I have...is what other stuff do I have to do to the TBSS E67 calibration to make it properly run the LS9? Doesn't the LS9 have some other ECM-controlled supercharger stuff? How is boost controlled on a factory LS9 (and GMPP LS9 calibration) calibration??? What additional sensors does the LS9 have that an LS2 doesn't?
    Whats interesting.....is that if I go in with the Tech 2 and build the vehicle as a 2009 corvette, and then go into bi-directional controls and turn on/off LS9-specific stuff (like the intercooler coolant pump)......IT WORKS!! So the TBSS E67 cal must still have LS9 stuff in it...its just un-used in TBSS. Either that, or when I went into B8028, etc and changed it to "YES" with HPT....it "wakes up" and "turns on" all the LS9 supercharger controls in the E67 TBSS calibration????
    Basically....now that the thing is running with no more check engine lights, ABS, speedo, factory gauges, cruise control, PRND321 display.......I just need to make sure that as far as running and making power safely, the TBSS E67 calibration (with supercharger stuff turned "on" with HPT) will run the LS9 properly, or as well as a factory Vette ZR1 LS9 calibration.
    I cant use an LS9 vette calibration, because the Vette uses only GMLAN...no Class 2 comms are enabled in the Vette calibration. TBSS is the only E67 calibration with Class 2 still enabled. Well, and the Chevy Colorado too also has E67/Class2, but I figured the TBSS calibration was the closest E67 cal I was going to get to an LS9.
    What say you guys?
    Ben
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Ben, wow, good job
    Fun stuff, as a TBSS guy, I have been wondering if the s/c code actually exists behind the scenes so this is good news!
    Just a heads up, I used PCMofNC's efan patches in EFILive format initially, but discovered they have updated their .hpt versions a few times and not the EFILive ones. I would download the HPT one and just mirror the settings in the HPT version of the tune, then flash that in.
    Nov 2005
    What other changes have been made to the HPT tune versions?? Is it worth it to do that whole hokey-pokey reflash song and dance again just to get the latest HPT patched file in there???
    The fans work just fine now...so im hesitant to screw around with it anymore...if it aint broke dont fix it?
    12.9s @ 108 mph
    Just a few, mostly related to after-run time and the PWM % for how the fans ramp on. It isnt enough to warrant me changing it on my personal truck with a 2 relay efan kit, but when I do my 3 relay fan harness swap and new fans I'll do it then. All of my customers get a tweaked version of PCMofNC's version, they're all running PCMofNC harnesses but I like to change a few on/off and after-run params.
    Nov 2005
    Ah ok. Yeah this is a very simple setup. Just one e-fan/relay. Its either on, or off.....so I dont see any need to reflash. It works fine, runs stable temp, doesnt overheat when left idling parked in a 70* shop, etc... Im just gonna leave it alone.
    12.9s @ 108 mph
    Yea, leave it then ha!
    Nov 2005
    Alright....made some good progress.
    Got the traction control working, NO codes, e-fans working. Just need to wire up cruise control!! So basically now its a factory-swap.
    Couple questions still...
    The 128k pulses-per-mile output on the ECM is still off...so after a mile or so of driving, the ABS module freaks out because the front wheel speed sensor signals are greater than 10% off from the rear wheel speed sensor signal. So basically we're cruising down the road and the front WSS is reading 25mph and the rear wheel speed sensor is reading 17mph. Or something like that.
    The E67 has a whole crapton of tables in the speedometer segment... H0102, etc. Yet I cant figure out what the hell they do. Some of them seem to change the 4k pulses-per-mile output to correct the speedometer.........but none seem to have any effect on the 128k PPM output....which is the one that goes OUT to the ABS module....which is the one we need to fix.
    Any ideas? Or better descriptions of how the speedometer and 4k PPM and 128k PPM outputs work on the E67 with a TBSS calibration in it????
    Like H0135... "factor??"
    thanks
    ben
    12.9s @ 108 mph
    Nov 2005
    The couple things that are still unknown....wondering if anyone had any input on these:
    LS9 has separate barometric pressure sensor and MAP sensor
    LS9 has two IAT sensors
    LS9 has the "boost control solenoid"
    Whether those are working or not with the TBSS calibration, im not sure. Its blizzarding here and the roads are covered in snow, so we can barely go 25% throttle without spinning out.
    If the TBSS calibration doesnt support the separate MAP/baro sensor...how would that effect running the boosted LS9 and how would the TBSS calibration react?
    And same with the IAT sensor. If only one IAT sensor is supported in the TBSS calibration....which IAT sensor location should I use on the LS9 into the TBSS ECM? The IAT sensor in the MAF sensor, or the second one? I assume the second one is post supercharger/intercooler....I havent looked that closely.
    And as far as the boost control solenoid...if the TBSS calibration wont control that properly, what are my options for manually controlling the LS9 supercharger?
    And final question...when tuning the LS9 on the TBSS calibration...I basically just opened up one EFILive instance with the GMPP LS9 calibration and a second EFILive instance with my custom TBSS calibration.......then I went through every single table and copy-pasted the LS9 tables into the TBSS calibration. I assume that should be pretty "safe" and "conservative" as far as a base tune? Not that im worried about it blowing up, but I just want to confirm my initial opinion that thats not a stupid thing to do....run it "as-is" right now with the "hybrid" TBSS/LS9 base tune.
    Ben
    12.9s @ 108 mph
    Nov 2005
    Tried playing around with just about everything in the ECM and TCM speedo segment tables...set the diff ratios to 3.55, 4.56, etc..
    NOTHING seems to have any effect on the 128k pulse-per-mile output. Which is critical to getting the ABS working properly and not set any WSS mismatch codes.
    WTF...hmmmm....ideas?
    12.9s @ 108 mph
  1. E67 ls3 - 480 cal
    By SBELGIO in forum Gen IV V8 Specific
    Last Post: March 19th, 2013, 10:57 AM
  2. BARO on E67 for N/A cal that is boosted
    By scdyne in forum E37, E38 & E67 PFI ECM's
    Last Post: August 6th, 2012, 12:47 PM
  3. E67 supported vehicles & Cal files (Updated 21-October-2008)
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: February 18th, 2010, 12:42 AM
