Results 1 to 2 of 2
Thread: LB7 help please
    May 2006
    Default LB7 help please
    I need some assistance/tips on building an economy towing tune for a 01 Duramax
    '98 Trans Am M6 02pcm w/ COS5,forged short block,coated pistons,L19(arp) studs/bolts,ported heads,242/252 610/598,LS6 int,LT's,ORY,4"mufflex,spohn suspension,moser 9",and a little juice
    Junior Member sfcjones's Avatar
    Mar 2008
    You would be better serve to go to a diesel forum of your choice if you need some help with building a tune. Depending on where you bought the tune some vendors will build a tow tune for free, just ask about it. Once you have it you can compare the tables and understanding what the tune represents.
    2004 GMC SLT LB7 CC Shortbed with Ranchhand Grill Guard; 273k+ miles
    4 KC off road light, Century Topper
    Hammer 4 Train Horns and Conductors Special at 150psi ; Westin Nurf Bars HypertechIII Powered 6.6 Dmax; Amsoil bypass filters & Amsoil in oil and tranny;Nicktane Fuel Filter, Scangauge II,Fumoto Valve, Active XM and Onstar,Protected by Viper and Tuned by EFI Live
  1. 02 LB7 No Start
    By 02CCSB in forum Duramax LB7
    Last Post: December 26th, 2015, 08:16 AM
  2. 01 LB7 PCM in 04 LB7 truck?
    By KLUG'S SS in forum Duramax LB7
    Last Post: December 26th, 2013, 02:25 AM
  3. RR for LB7
    By GL4787 in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 8th, 2009, 02:12 PM
  4. Need OS for 01 lb7 pcm
    By red12secz28 in forum General (Diesel)
    Last Post: November 21st, 2007, 06:26 AM
  5. 03 LB7 pcm into 01 LB7
    By red12secz28 in forum Duramax LB7
    Last Post: November 19th, 2007, 10:40 AM
