Results 1 to 10 of 16
Thread: Charge Temp Blending, no MAF
    Feb 2013
    Default Charge Temp Blending, no MAF
    If the MAF is disabled, does charge temp blending still function?
    Yes.
    Sep 2012
    Does this b4901 work on 98's?
    My understanding is that it does, regardless of MAF, on 1997/8 also.
    Feb 2013
    What would really be great is the option to edit the PCM’s IAT fuel adjustments. Seems it’s not tunable in the 1998...? Moving the IAT sensor to a location where temps are more consistent has helped tremendously - I’m no longer running lean after sitting in a parking lot… but I’m still running a tad too rich in cooler weather. I’ve got my tune right where I want it, now I’m anticipating a 95+ degree Florida summer soon. Do I need a better operating system? Or have I overlooked something?
    Should be ok... altho some people swap to 0411 PCM (requires harness mod, IPC wiring mod, and fuel system segment).
    Sep 2012
    That's good to hear cause I kept reading that 98's had this table as a "dummy" table. Since the weather has warmed up in FL, I noticed that after my car runs for awhile and the ECT/IAT's are up, I lean out. This is with an OLMAF tune currently. Struck me as really odd since I tuned the car in the cool weather, until I started digging into it and realized the PCM thinks theres less dense air so it commands less fuel.
    I also wish for an IAT vs. fuel enrichment, but no such luck for the 98's.
    Feb 2013
    Quote Originally Posted by ddnspider View Post
    Have you relocated your IAT sensor? I used a 24" extension to put it behind my right marker light, down away from the hot engine. Picks up actual air temps now, and so far, the lean issue is gone.
    You could run an experiment: drastically alter this table and see how engine runs.
    Sep 2012
    Quote Originally Posted by 12_Square View Post
    I plan to relocate the IAT in my bolt on z28 to use the EGR opening in the intake manifold after seeing others do it with good results. However on my 98 turbo TA I need it in the intake track to keep a handle on IAT's and spark retard.
    That is actually the game plan to try.....now just need to get the time to play with it lol
  1. Reduced power,Coolant over temp,Trans over temp
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 2nd, 2011, 10:12 AM
  2. Reduced power mode,Coolant over temp,Trans over temp
    By driver456 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 1st, 2011, 10:04 AM
  3. Speed Density Charge Temperature Blending (E40)
    By Gelf VXR in forum Gen IV V8 Specific
    Last Post: June 28th, 2008, 04:36 PM
  4. charge temp blending
    By 5.7ute in forum Custom Operating Systems
    Last Post: February 8th, 2007, 04:07 PM
  5. Intake charge blending, surgery time.
    By ringram in forum General (Petrol, Gas, Ethanol)
    Last Post: June 19th, 2006, 07:26 AM
