So I installed a LQ4 DBW engine in my 86 K10 and had to mod the pedal to fit in the 86 I cut the arm off and welded the 86 pedal on the TPS I started the engine and it wouldn't idle it ran at 3K shut it off hooked up the efi live and saw the the TPS is staying at 20% nothing is holding it up it is going back tot he rest position. is there a way to calibrate it or did it get messed up welding on the arm?
