Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Any idea why this OEM table is so strange?
    Dec 2012
    Default Any idea why this OEM table is so strange?
    Seeking help from EFI tech support...
    Why is this 3500 LMM van high altitude table (in the unmodified oem tune)
Name:	LMM 3500 van torque-based fuel at high alt, map.PNG
    is so different than the low & medium altitude tables?
Name:	LMM 3500 van torque-based fuel at low & med alt.PNG
    Also, none of the tables for an LMM 3500 pickup or 5500 Topkick are like that:
Name:	LMM 3500 pickup & 5500 Topkick torque-based fuel at high alt.PNG
    THEFERMANATOR suggested elsewhere that this could just be a mis-scaled table.
    But the table data itself matches what is shown on the map of that table:
Name:	LMM 3500 van torque-based fuel at high alt, table values.PNG
    My concern is that there may have been some type of read or interpretation error between what is actually on the ECM and what shows up in the table in the .tun file. I did read the oem tune off the ECM three times, and in all cases this table is the same, so at least it's consistent.
    If this table does have erroneous data in it, I could run into a problem even if I flashed the same .tun back to the ECM.
    But in this case I might not ever see any adverse effect unless the vehicle was at high altitude.
    Any suggestions would be greatly appreciated...
Name:	LMM 3500 van torque-based fuel at low, med & high alt.PNG
    That looks like a case of the table size is not what EFILive is expecting, don't alter the values.
    Very odd that is the first instance of this reported for an LMM considering how long programming for them has been out, are you able to please Email support@efilive the stock tune from that vehicle.
    Thanks,
    Dec 2012
    Thanks,
    Email sent.
    FWIW, the oem tune is posted here:
    http://www.tunefiledepot.com/calibra...(12628594).tun
    Oct 2004
    No email received as yet. Please resend.
    Andrew
    EFILive Crew
    Dec 2012
    To: support@efilive.com
    Subject: re: why is this OEM LMM table so strange?
    Date: Mon, 24 Feb 2014 20:38:06 -0700
    It's also posted here:
    http://www.tunefiledepot.com/calibrations/stock
    Dec 2012
    I sent it again just now. You can also access the tune at this link, also in the post above.
    2010 Savana Automatic 6.6 Litre (LMM) 12628594 (ECM) E35 1.8 M
    Oct 2004
    Came through this time. I have forwarded on.
    Andrew
    EFILive Crew
    Ok the problem is as suspected, on that vehicle instead of the table being the normal 23 x 23, GM made it 17 x 22, why oh why!
    The problem for EFILive is it only knows that table as 23 x 23 for that OS (it shares the same OS number as the trucks), for now, just don't touch that table until we figure out a solution to this problem.
    Dec 2012
    Thanks...
    But I see the same number of rows (23) and columns (23) in both tables.
    However, I am using the northern hemisphere standard for counting
    (sorry couldn't resist; don't hold it against me. New Zealand is where I always wanted to go when fleeing the Zombie Apocalypse)
Name:	LMM Van B1169.PNG
ID:	16448   Click image for larger version.
Name:	LMM pickup B1169.PNG
    Dec 2012
    Now that I've stared at it long enough, I also see what the problem may be...
    OK, hopefully it's easy to see what I did here:
Name:	LMM Van B1169 (altered).PNG
    Every column of cells in the out of whack triangular section in the original table has been moved as far down as each column can go.
    The cells that were in the bottom row in the original table are denoted by a light blue background color.
    Every partial column of cells that was originally below that triangular section has been moved up as far as each column could go.
    It looks like this fits fairly well, however there appear to be a few possible transpositions, which are denoted by the dark blue background.
    The thing is, I found this because it was so visually obvious.
    What has me concerned is the possibility of other tables that could have errors that aren't so obvious.
    As to why this might not have shown up before now, since the LMM has been out so long...
    GM didn't build many LMM vans compared to the number of LMM pickups, and far fewer van owners modify their vehicles at all, and of those who do, most send their original tunes off to a tuner and hope for the best, and may never have really scrutinized the tables closely.
  1. Strange VE Table?
    By tinindian in forum Gen III V8 Specific
    Last Post: May 16th, 2011, 10:54 PM
  2. B6001 dwell time strange table.
    Last Post: October 5th, 2009, 06:04 PM
  3. COS3 back to OEM OS question..........
    By FreddyG in forum Gen III V8 Specific
    Last Post: July 19th, 2008, 02:17 AM
  4. Strange numbers in knock table
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: October 13th, 2007, 07:25 AM
  5. NEW IDEA! Boost Builder table!!
    By nitrorocket in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 2nd, 2006, 09:27 AM
