Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Dual WBO2 to V2 over serial??
    Sep 2014
    I had that feeling guess I'll do one analog and the other serial and compare the 2
    Member Dirktdolman's Avatar
    Oct 2014
    What about the SM-AFR. I was thinking about buying two.
    Quote Originally Posted by Dirktdolman View Post
    Analog: they will work fine.
    Serial: I don't know if you can daisy chain them.
    Oct 2014
    I sent them a message to find out. Will let you know when I hear.
    Lifetime Member samh_08's Avatar
    Oct 2008
    I was just going to start a thread with the same question. I just received my LM-2 and already have a LC-1 connected serially.
    The LM-2 is mainly for other vehicles, but for kicks I wanted to hook it up along with my LC-1 so I could monitor both banks.
    Im guessing I need to make a molex ---> RJ11 (Telephone) to connect the LM-2 serially by itself, then a 2.5mm to 2.5mm connector for when I want to run it with the LC-1?
    How does one configure the V2 to see both widebands with one input?
    Hi Sam,
    Innovate widebands know how to serially daisy chain...
    remember you need:
    - Terminator plug goes into WB1 SERIAL-IN,
    - WB1 SERIAL OUT goes WB2 SERIAL IN,
    - WB2 SERIAL OUT goes thru null modem bender to FSV2.
    See post #3 here: Setting-up-a-FSV2-from-scratch
    You will see a setting for selecting 2 widebands.
    Oct 2008
    Thanks Joe, I just didnt know how the V2 was supposed to see each wideband individually.
    Googling 'Null modem bender' doesn't look like the TAQ cable used to look. I cant get a hold of him about buying a cable, is there someone else that sells something or has some instructions for making your own?
  9. #19
  1. AutoCal WBO2
    By L31Sleeper in forum AutoCal
    Last Post: January 2nd, 2011, 05:16 PM
  2. Bug > Serial WBO2 Lambda and EQ mixed up
    By nevinsb in forum FlashScan V2 BB Logging
    Last Post: June 16th, 2009, 08:57 AM
  3. Installing wbo2
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2008, 10:20 AM
  4. wbo2 opinions
    By warscout2 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 30th, 2007, 03:16 AM
  5. Which WBO2 would work the best for......
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 27th, 2006, 02:41 PM
