Results 1 to 9 of 9
Thread: 2013 cab chassis tune
    Jun 2012
    Default 2013 cab chassis tune
    I have a 2013 cab and chassis. I was told by a engineer from GM that it was a detuned pickup engine and it had 40 hp less. does anybody have any idea on getting a tune to raise it to a stock 6.6. he told me I had to go to a dealer that I new that would be willing to change the entire programming on the truck which would entail changing the trucks vin to the one they added to regain the hp . anybody got a any ideas
    I would seriously doubt any GM dealership would do that, if something went wrong they would be liable for the warranty repair, GM's system has a number of checks in it to make sure they cannot do this (though it can be done).
    You probably need to speak to a performance tuner shop about getting something like this done.
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    Shoot me your vin of the "detuned" truck and I will look up the programming that is in it and report back. Kory@LAtuning.com
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
    Jan 2014
    can you flash an LGH with an LML cal?
    Nov 2009
    Quote Originally Posted by RADustin View Post
    It will throw egr codes, etc if you do.
    -Kory
    Jan 2014
    I understand. Good to know. Easy enough.
    Jan 2006
    I just tried this the other day I got a Egr cooler bypass code high voltage. I don't remember the exact code, but I could do it again if you want to know it. Truck did run but it went straight into limp mode. I'm pretty sure there is no bypass on the LGH and I didn't know the LML had one but I did see a PID in the scan tool from the Egr cooler bypass percentage and tried it with no return data.
    04 LB7
    2010 LMM
    2015 LML
    Jan 2014
    we should be able to fix that soon. I found all the egr codes.
    Jun 2012
    Quote Originally Posted by Dmaxink View Post
    sent you the VIN to your email
  1. I need an 01 3500 cab and chassis tune file
    By Madspeed in forum Duramax LB7
    Last Post: November 4th, 2013, 08:13 AM
  2. Looking for 2003 LB7 Cab and Chassis Tune
    By Zorganov in forum General (Diesel)
    Last Post: September 14th, 2013, 12:39 AM
  3. 08 Sterling Bullet 5500 6.7 Cab and Chassis
    By Reubine in forum Cummins 6.7L
    Last Post: August 26th, 2013, 06:08 PM
  4. Need an LBZ cab and chassis tune
    By THEFERMANATOR in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 8th, 2012, 01:20 PM
