Results 1 to 9 of 9
Thread: Big Injector (2150cc) & 6l90 Tuning
    May 2013
    Default Big Injector (2150cc) & 6l90 Tuning
    Ok we know if your MAF is incorrectly scaled the TCM receives an erroneous torque value and makes incorrect shift adjustments. Why it is so critical to have a spot on engine tune with the 6L80/90.
    With the above stated getting the 2150cc injectors scaled correctly the MAF has been divided x2 (50%) so they are low thus causing issues with the trans now. Few people I talked said to mess with the PE table but that's wot what about cruising. Even with messing with the PE tables I don't think we will get the MAF back in line but maybe 20%.
    Not sure on options but few ideas floating around in the air now.
    1. Relocate the MAF sensor to the intercooler tank.
    2. Go to a lower cc injector (ID1300) and mess a little with the PE table to get things in line.
    Thoughts? 1076rwhp on e85 (low boost) thus far but I want moar but I want a shifting trans too lol.
    Have a read of this thread: Improving-shifts-via-the-ECM
    you will have to manipulate those Torque Model tables to firm up the shifts.
    May 2013
    The issue is the MAF is low due to the bigger injectors. I'm tuning the trans via hptuners.
    The thread I pointed you to shows tables for adjusting the ECM's torque calculation... IDK if HPT shows those tables, if it doesn't then there's not much you can do.
    May 2013
    They function the same on hptuners. They call it torq EQ ratio and it's maxed out. The deal is the trans reads via the maf well the maf been dropped 50% to get the injectors (2150cc) to work thus creating a issue. Max injectors you can run is 1000cc without having to touch the maf.
    Post a pic of that table...
    May 2013
    Got things back in line. Was able to add 30% back in during the cruising which fixed a lot. Think to bring things closer I'm going to play with the PE tables for wot.
    Lifetime Member darcy's Avatar
    Feb 2012
    Quote Originally Posted by 1INSANEV View Post
    Max injector size before scaling varies between operating systems, some E38s only allow ~600cc/min before scaling is required due to flow rate limits.
    The TCM is told engine torque by the ECM. Which the ECM has calculated via a complex equation (similar to VVE).
    When you lie to ECM about how much air is really coming in, by scaling the tune, you need to bump the calculated torque back up - by appropriately altering the equation co-coefficients - so that the ECM reports a true torque value to the TCM. EQ Ratio is only one of the coefficients; maxing it out alone won't fix the problem as it's only part of the equation.
    Aug 2005
    Another option would be to halve the injector flow rate and double the Stoichiometric air/fuel ratio. All spark and airflow reference will be correct and torque calculation will as well. Haven't stumbled on a vehicle yet that didn't work with that option.
  1. Big VE Difference Between AutoVE & Calc.VET
    By tinindian in forum Gen III V8 Specific
    Last Post: May 9th, 2013, 02:33 AM
  2. HELP Tuning with no wb? 4.8 with big cam!
    By T&A Custom Rides in forum Gen III V8 Specific
    Last Post: January 26th, 2012, 10:40 PM
  3. lean wot with big ve numbers and low injector duty cycle
    By 69camaro5speed in forum Custom Operating Systems
    Last Post: July 28th, 2007, 04:48 PM
  4. Big cams and VE tuning
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: July 26th, 2006, 06:27 PM
  5. help with tuning AC with big cam
    By 01blkss in forum General (Petrol, Gas, Ethanol)
    Last Post: June 18th, 2006, 01:48 PM
