Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: I need help!
    Mar 2009
    What about the radio interface? It isn't normally teh radio, but the interface for the radio that causes the bus to not go quiet to allow the V2 to communicate.
    Member 06megatuned's Avatar
    Dec 2013
    Radio interface? I pulled the radio fuse and pulled the radio out of the dash and unplugged it all.
    2006 Mega, built billet ATS, BD towing twins.
    Mar 2009
    03+ trucks use a radio interface with an aftermarket radio because the factory radio is integrated into the data bus. It needs it to turn the radio on and off, as well as for the factory warning tones to be heard since they use the radio in 03+ trucks for those functions.
    Dec 2013
    How do I do this?
    Senior Member garrettg.bpd's Avatar
    Jun 2013
    I've seen this before. Try checking the try alt keys box when you read the pcm.
    Apr 2014
    I'm having a similar problem no matter what I do I cant tune my duramax I have an aftermarket head unit in it and ive tried everything I could I had my ECM sent out to another tuner and he said my ECM was fine. any help would be greatly appreciated
    Jun 2011
    If it has a remote start pull everything off.
    Dec 2013
    I had to break down and build me a bench harness for my lly customers.
