Results 1 to 4 of 4
Thread: E78 Coolant Temp Control
    Dec 2005
    Default E78 Coolant Temp Control
    Just wondering if there is a way to add the tables in 12655943 and other Cruze/Sonic Calibrations for commanded engine coolant temp as related to the electric thermostats that the Cruze and Sonic are using. It appears that these engines run very high temps. This may be a factor in spark knock and cylinder temps.
    I think GM changed the coolant temp controls on the later OS's, haven't figured out how they work yet I'm afraid.
    Nov 2013
    Any update on this? Need to have the fans come on sooner on a Sonic turbo
    Feb 2006
    I'd like them on the e83 too, I asked hpt to look into it to but they wont be spending any more time on the e83 unfortunately.
    The weird thing with the e83, when you force open loop mode, the ect will sit on 78c. Which explains why when you go wot, thus OL the engine temp goes down. Any other time it sits between 102-106c
  1. Engine Coolant Temp Sensor
    By auspeed in forum Gen III V8 Specific
    Last Post: June 29th, 2013, 01:09 PM
  2. Reduced power,Coolant over temp,Trans over temp
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 2nd, 2011, 10:12 AM
  3. Reduced power mode,Coolant over temp,Trans over temp
    By driver456 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 1st, 2011, 10:04 AM
  4. coolant temp and VE tune
    By mtnman in forum General
    Last Post: April 14th, 2006, 12:30 PM
