Ok thanks for looking though and will try your idea on friday this week regarding b4105
regards
gav
regards
gav
Is 9 degrees spark timing at idle ok, should it be higher...?
Hi Joe,
i only have the precat o2 sensors if that is what you meant....
regarding spark, for idle 10deg it is very stable, for free revving fast idle 40deg ish. Would playing with these timings have much effect on the CO readings?
many thanks for your time with this.
regards
gav
Ah, of course, then as statesman said, we can't tell how well your cats are operating.
Hello,
fast idle and idle both passed without me altering tune. All i did before going this time was wrap my sidepipes as they exit the body. So IVA test here we come and if i need to up the lambda then i know what to try.
first time really driving the LS1 and something i have noticed is that there is no engine braking when i remove foot off the throttle, cable by the way. The engine just keeps revvs up and like that when i pull up to a stop, then eventually drops back to idle rpm. Strange and will have to fix this sometime.
thanks though for help so far.
regards
gav
Can you post your detailed test results here...?
Engine braking: several things need to be looked at: DFCO, throttle follower, throttle cracker, and possibly others... post some logs.
Gav,
Bucket loads of engine braking is available with a bit of tweaking, the cruise control feeling is TC or TF related normally.
Jim
2000 LS1 M6, No EGR/Air/PS/CATs. TR230 Cam, COS3, OLSD, LC1 Wideband fitted, Procharger P1SC, 2 Bar MAP, Siemans Dekka 60Lb Injectors.
All wrapped up in a 2000Lb AC Cobra Replica
Will post results joe. Probably be a while before i can drive it again now as will be waiting for uk iva test.
Jim, is that you from uk cobraclub?
regards
gav
Same one ;-)
Jim
