Joe (Moderator)
Are you using the V2's internal flash memory to store the ECM/pidlist...?
If so, you need an external SD card (plugs into SD slot in top of V2)... and you need to tell V2 to use the external SD card.
Yes I have figured that part out, the problem I was having was I had all the DTC discriptions turned on. I got the PIDs loaded and did some data logging, now I am trying to figure out how to view the logs.
Where can I find the directions for opening the logs and viewing them????
Joe (Moderator)
Start V8 EFILive Explorer, goto the Scan tab, click Home (observe which folder upper pane positions itself on), drag log files from lower pane (V2) to upper pane (PC/laptop); [ then, also, delete log files from lower pane ]... exit when done;
and then use V7 scantool or V8 scantool to view logs on PC/laptop.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
