Originally Posted by
darcy
Hi there kkslds,
I only had a quick look, but there a few things the come to mind quickly that might be causing you problems.
I'm surprised it's lean, most things point to being rich.
Have a look at:
A0014 - should not be set flat to 1.2 across the board, this is a global multiplier of VE based on IAT
B0101 - looks big, particualrly at low RPM/MAP for a cammed engine (~ +50% on a stock VE table)
B4001 - do you really have 37lb (@3bar) injectors? (THIS would create lean issue if you don't have injectors this big)
B5914 - low octane spark is the same as high octane, set it lower (wont affect fueling problem though)
Are you trying to run in SD mode?
C2901-C2906 suggest you are BUT P0101-P0103 are set to NON
Did you have a good running stock OS since the heads and cam that you are working from, or is it all new?
I think you need to provide a few more details of your setup for us to help.
