1st tune i've built with efilive. I need someone to check over my tune & see if there is anything else that can be done to get more lo-mid range power, take off, throttle response out of it. I still can't spin the tires for some reason. Also see if anything needs to be changed in the tune. Help greatly appreciated!!
2005 Chevy 2500HD 6.0L Gas 4WD w/4L80E Trans
Mods: Airaid Cold Air Intake/Throttle Body Spacer, Magnaflow Exhaust, No CATs, Yukon 4.56 Ring & Pinion, Yukon Posi-Trac Locker, 3 Inch Lift, 35 Inch Mud Grapplers, Trans-Go Shift Kit.
ALWAYS RUN 93 OCTANE
Modded Tune is MY TUNE. Other is FACTORY TUNE for my truck:
LS1BKyle_Modded2.ctz
2006 Chevrolet Silverado Truck Automatic LQ4 6.0 Litre (12587811).tun
