Made Changes to previous tune:
Transmission Calibration.Desired Shift Times
{D1108} Desired 1-2 Shift Times, modified.
{D1109} Desired 2-3 Shift Times, modified.
{D1110} Desired 3-4 Shift Times, modified.
__________________________________________________ ______________________________
Mar 20, 2014 16:42:14
Transmission Calibration.Trans Pressures
{D0701} Base Pressure 1->2 Shift, modified.
{D0702} Base Pressure 2->3 Shift, modified.
{D0703} Base Pressure 3->4 Shift, modified.
Mar 20, 2014 17:11:41
Engine Calibration.Fuel.Mixture
{B3609} PE Delay Counter Adjustment, modified.
Mar 20, 2014 17:16:31
{B3615} Hot PE Mode Enable, modified.
{B3616} Normal PE Mode Enable, modified.
Engine Calibration.Abuse Management
{B1207} Abuse Management Vehicle Speed Threshold, changed from "256" to "1".
Mar 20, 2014 18:13:33
{B3608} Delay before Entering PE Mode, changed from "60" to "0".
Truck has alot more top end response & shifts better!! This is the NEW TUNE & a LOG:
LS1BKyle_Modded_New Tune.ctz
LS1B_Kyle_NewTune.efi
Any other suggestions or tips?? Loving the improvements!!
