Results 1 to 9 of 9
Thread: 5.3 --> 6.0 cal changes
    May 2010
    Default 5.3 --> 6.0 cal changes
    Any changes that need to be made to a 5.3/4L60 cal 12212156 OS when switching from 5.3 to 6.0? Injectors are the same, probably just change the cylinder volume and run a couple CalcVET sessions?
    Injectors are all the same, so no issue there, but I figure I'll just get the LQ4's VE into the 5.3 tune, change cyl volume, copy and paste timing tables then run a few tuning sessions. Both engines are '02, so damn near identical minus displacement and flexplate/spacer change.
    Anything I'm missing?
    Thanks guys
    Mike
    Cylinder volume may not really do anything (it seems to be a documentative parameter, I've seen it incorrect in various files)...
    yes, try Calc.VET
    ( use g*K/kPa units for VE )
    May 2010
    rog thanks joecar
    Cylinder volume comes into play when you view VE in % units... it does not do anything when viewing VE in g*K/kPa.
    ( VE in g*K/kPa directly provides "normalized" (for pressure/temperature) cylinder airmass at the operating point (MAP x RPM) regardless of cylinder volume or displacement )
    May 2010
    So I think I have my completed product for the swap, if someone could look it over I would appreciate it. extra sets of eyes and all.
    Going from the 98 L31 with 98 trans being run by 0411 12212156 with modified 02 Express cal.
    Swapping in the 04 LS1 with truck intake/accessories and staying with the 98 trans. Also swapping in a '96 2100 rpm converter from an S10. I have verified that this TC has the same spline count, EC3 logic and PWM control as well as the same type of clutch material as the TC that is currently installed.
    Running flex fuel injectors and regulator from an 02 Yukon, changed all the injector stuff as well as using the timing info from an '02 Camaro LS1/auto.
    I've also segment swapped my 'original' trans info from the express/tahoe cal into the '02 calibration because the trans is a 98 and it operates very well as it sits as well it making sense to control a 98 trans with the same logic, not using the 99-02 trans logic for a 98 trans.
    THanks guys
    finished product-->1998 Tahoe LS1 (12212156).tun
    current 0411/L31 Tahoe cal-->Tahoe_CURRENT.tun
    Source calibrations (in addition to current Tahoe)
    2002 Chevrolet Camaro Coupe Automatic LS1 5.7 Litre (12212156).tun
    2002 Chevrolet Tahoe SUV Automatic LM7 5.3 Litre (12212156).tun
    2002 GMC Yukon Truck Automatic L59 5.3 Litre (12216125).tun
    Set D0961 and D0962 to zeros to prevent interfering with the PT upshift/downshift tables (same as D0960).
    May 2010
    Will do, thanks joecar
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    Quote Originally Posted by bmd2_colo View Post
    THanks guys
    flex-fuel injectors and regulator from an 02 yukon?? I was 99.9% sure flex-fuel didnt start until 03?
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
    May 2010
    The L59 is the flex fuel 5.3, looks like they started in 02.
  1. Where's the Auto Cal
    By L31Sleeper in forum General (Petrol, Gas, Ethanol)
    Last Post: July 23rd, 2010, 05:30 PM
  2. Cal or OS
    By L31Sleeper in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 18th, 2009, 10:10 AM
  3. 07 C6 A6 Speedo Cal
    By Mike@Vengeance in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: December 18th, 2008, 03:26 PM
  4. 4.3 cal. files?
    By JODAGR in forum Vortec V6/V8 Specific
    Last Post: January 25th, 2007, 06:21 AM
  5. What are the .cal files for?
    By hpcubed in forum General (Petrol, Gas, Ethanol)
    Last Post: July 21st, 2005, 09:49 PM
