Results 1 to 4 of 4
Thread: Help, pass through active!
    Aug 2008
    Default Help, pass through active!
    I was loading a tune in and it literally just got right the the pop up window where i was about to turn the key off and wait for the count down. My laptop died on me!! The truck starts and runs fine. But I can't log, view codes etc. it just says pass through active. How can I remedy this? I'm guessing (haven't tried) maybe it won't even let me hook up the laptop anymore
    Aug 2008
    Bump. Maybe I should have put this in a different category then diesel
    "Pass-thru active" is just a mode in the FlashScan V2 device that gets set while reading or flashing a controller to prevent any accidental key presses on FlashScan's keypad from interfering with the read/flash process. Normally at the end of a read/flash the PC will send a signal to FlashScan to tell it that pass-thru is complete. When you laptop died it had not sent the "pass-thru is complete" signal.
    You can reset FlashScan by unplugging it and replugging it (i.e. cold boot), or by pressing Ctrl+Backspace (i.e. warm boot)
    Aug 2008
    Thanks, I connected it to the scan tool with the laptop after a recharge. Then disconnected it. Works fine now, big scare though but I'm good!
  1. RTACS not active
    By bvd80 in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 24th, 2010, 07:43 PM
  2. Pass through logs corrupt..?
    By samh_08 in forum FlashScan V2
    Last Post: April 19th, 2009, 03:13 PM
  3. RTACS is NOT ACTIVE
    By driver456 in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 6th, 2008, 12:45 PM
  4. Can't pass emissions?
    By WS600 in forum Gen III V8 Specific
    Last Post: March 11th, 2008, 12:37 AM
  5. RTACS is Not active!
    By DrX in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 25th, 2007, 01:13 PM
