Results 1 to 4 of 4
Thread: LLY Can't flash back to stock
    Mar 2014
    Default LLY Can't flash back to stock
    I have a 2005 LLY with EFI live and I have been having some boost issues so I wanted to flash it back to stock to see if it's the tune causing the issue. There are 0 codes being set, not even in history. I used the tech2 to check for codes since I am a mechanic at a GM dealer. Programming through TIS fails every time. Doing both regarding programming and replace and reprogram. I've got remote start and aftermarket stereo. I've tried pulling the abs, info, amp and radio fuses and removed the stereo and remote start. Still doesn't reprogram. We had another truck in the shop that was an 05 LLY and I put my ECM into that truck to try and program it since it was completely stock and it still failed. EFI can be reflashed but stock can't. Anyone have some suggestions? I've tried programming using the MDI, and tech2 legacy pass through and just with the tech2.
    Dec 2005
    The seed key pair is most likely not right, EFI can try "ALT" keys and get a flash.
    It should not matter if it is a stock EFI file or a DSP2 or DSP5 that is modded.
    EFI can flash when all else fails
    www.mscservices.net
    Mar 2014
    Okay Well I am planning on getting a tune from Idaho Rob. That should flash over top of the tunes I have right now without a problem right?
    Mar 2014
    Can anyone with a mild max Idaho Rob tune tell me what there truck runs at for boost on a dsp5 setup?
  1. DSP5 back to Stock Question
    By Intel in forum General (Diesel)
    Last Post: July 9th, 2012, 05:04 AM
  2. Back to stock?
    By JWolfe75 in forum Custom Operating Systems
    Last Post: July 17th, 2011, 07:14 AM
  3. How do I put the stock os back in?
    By Jason S. in forum General
    Last Post: July 23rd, 2010, 07:41 AM
  4. LS1 Edit back to stock
    By Chriskaw7r in forum Gen III V8 Specific
    Last Post: February 22nd, 2010, 04:32 PM
  5. custom os back to stock
    By minytrker in forum Custom Operating Systems
    Last Post: June 11th, 2006, 10:55 PM
