hey guys just curious to what is a normal daily driver intake temp is ?
mine can get upto 45degs but seems to be 35 or lower of boost.
I've only got a china front mount so wondering if i should upgrade to a better quality one.
cheerz
cheerz
45C isn't bad for cruising. In the Summer months here in the middle of the US, I can see temps reach 60-61C if stuck in town with stop/go traffic. The biggest thing would be how much temperature rise do you see when in boost with your current intercooler? If its only a few degrees, when not heat soaked, then I would call it good. If your raising say 20-40F, I would start looking for another intercooler.
LQ4, Pro-Flo, heads, Stock48 cam'd, twin TO4E 2001 C5 830rwhp/905rwtq
2001 GMC RCSB pt88/5.3/4l80e/14 bolt 11.34@123.2 best pass so far with a 1,82 60' @ 13lbs boost
yeah thanks for reply mate
seems that my current cooler isn't doing that bad of a job.
only reading pre intake temps but, will try measure before and post cooler see how much its changing
