Results 1 to 5 of 5
Thread: pid not supported
    Feb 2014
    Default pid not supported
    when im trying to do the ( rafpn ) the pid idle air flow correction ac off pn says that it is not supported and I get a line through the name on the map for the desired airflow
    Im trying to log the b4307 so I can do the rafpn
    Im posting a quick log I made so you can see what im talking about
    For the pid CALC.RAFPN you need to select it's prerequisite pids (on PIDs tab, on CALC.RAFPN pid do rightclick->More Info to see which ones).
    Feb 2014
    I did that but there is one pid it is saying that it doesn't support
    it says I need these 3 pids
    Engine RPM
    Engine Coolant Temperature
    Idle Airflow Correction AC Off, P/N (Grams/s)
    the 3rd one is the one it says is not supported
    Quote Originally Posted by efilivesteven View Post
    This one is CALC.RAFPN
    on it do rightclick->More Info
    this pid requires GM.IAC_LTPN_DMA.gps and GM.IAC_STPN_DMA.gps
    did you select those 2 pids also...?
    Feb 2014
    No i didnt know about that more info thing on the pids thnx for the help that fixed it.
  1. calc.pid /sae.generic - pid resoultion question
    By cyipher in forum Gen III V8 Specific
    Last Post: February 6th, 2014, 01:00 PM
  2. pid's showing not supported
    By pero648 in forum FlashScan V1
    Last Post: July 20th, 2013, 04:24 PM
  3. e38 dma pid SCALEDCORVE_ doesnt work plus a bad calc pid
    By ringram in forum FlashScan V2 BB Logging
    Last Post: November 30th, 2008, 11:28 AM
  4. Unsupported PID's? Making them "supported"
    By N0DIH in forum General (Petrol, Gas, Ethanol)
    Last Post: October 7th, 2008, 10:40 AM
  5. Replies: 2
    Last Post: November 30th, 2005, 03:50 PM
